Question about Frigidaire ATF6000ES Front Load Washer
The washer is not runing
The door is not closing properly, when I turn on the washer ther is alittel nois and no runig the whasher, and no water ruing.
    Novelist:
  • 117 Answers
The door locking mechanism may need replacing. IF the door doe snot shut properly, it does not complete a circuit on the main control board and the washer will not advance to the next electronic cycle. IN this case, fill.....Check your door switch and repair or replace as needed. If I can help further. Eric Campion
Posted on Feb 21, 2009
Bosch frontloader will not spin or agitate
You can check the following things in your washer:
1. Is the washer door or lid closed?
a. If yes, does it filled with water?
b. if no: Please contact the manufacturer to replace the door latch.
And if it is not filling properly then there is a water supply issues like: hot or cold faucets closed or not open completely, hot and cold hoses reversed, kinked or pinched fill hoses, plugged inlet screens or insufficient water pressure
Jul 22, 2016 | Bosch Washing Machines
After I change the fuel pump wen I try to sart my car I hearthe pump keep runig and the car don`t start my car is 1997 Jeep Cherokee sport 4.0 6 cil.
Ok calm down the fuel pump works find someone to computer scan for codes. check for fuel pressure at engine an spark
Nov 21, 2015 | 1997 Jeep Grand Cherokee
Miele Novotronic W 832 washer won't turn on. It suddenly turned off after trying to open the door and now it won't turn back on. I tried switchinging powersources, didn't work.
Make sure the door is properly closed!!! The door opener is electric, and the electrics are turned off unless the door is properly closed, hence with the door closed but not fully "home" you will neither be able to re-open the door nor wash what is in the machine. Just give the door a firm push closed and it should spring to life.
Apr 27, 2011 | Miele Novotronic Premier 500 Front Load...
Cleaning a front load washer for mold and mmildew
What's the question?
Use a mild bleach
heres the solution from washing machine manuals, dont know why fuses and powerre included in this...
odor in washer
• Water supply taps are not
open fully.
• Water line hoses are kinked,
pinched, or bent.
• Water inlet filters are clogged.
• Water pressure to tap or
house is too low.
• Power cord is not properly
plugged in.
• House fuse is blown, circuit
breaker has tripped, or power
outage has occurred.
• The door is not closed
properly.
• Incorrect or too much
detergent has been used.
• Inside of tub not cleaned
properly.
• Make sure that the water taps are open fully.
• Make sure the hoses are not kinked or pinched. Be
careful when moving the washer.
• Clean the inlet filters. See the Care and Cleaning
section.
• Check another faucet in the house to make sure that
household water pressure is adequate.
• Make sure that the plug is plugged securely into a
grounded, 3-prong, 120-VAC, 60-Hz. outlet.
• Reset circuit breaker or replace fuse. Do not increase
fuse capacity. If the problem is a circuit overload,
have it corrected by a qualified electrician.
• Make sure that the door is closed properly and press
the START/PAUSE button. After starting a cycle, it
may take a few moments before the drum begins to
turn or spin. The washer will not spin unless the door
is locked (DOOR LOCK will appear in the display).
• If the door is closed and locked and the open door
error message is displayed, call for service.
• Use only HE (High-Efficiency) detergent in accordance with the
manufacturer’s instructions.
• Run the TUB CLEAN cycle regularly. Be sure to wipe around and
under the door seal frequently.
• Clean around door seal/glass to prevent odor or mildew:
1. wipe dry the door seal/glass and the door opening area
2. wipe around the inner drum/door seal and the lower door seal
Aug 20, 2009 | Samsung Washing Machines
The door is locked, no light on, washer won't run
Is the power cord plugged into a grounded 3 prong outlet?
Plug power cord into a grounded 3 prong outlet.
Are you using an extension cord?
Do not use an extension cord.
Has a household fuse blown, or has a circuit breaker tripped?
Check to see if a household circuit breaker or Ground Fault Circuit Interrupter (GFCI) outlet has tripped. If so, reset the circuit breaker or Ground Fault Circuit Interrupter. If the washer is on a fuse box, check to see if a fuse has blown and replace it, if necessary. If the problem continues to occur, call an electrician.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on. The washer will not operate properly with only one incoming source of water.
Is the water inlet hose kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove the inlet hoses from the washer. Remove any accumulated film or particles. Reinstall hoses, turn on water and check for leaks.
Is the washer in a normal pause in the cycle?
The washer pauses for about 2 minutes during certain cycles. Allow the cycle to continue. Some cycles feature periods of tumbling and soaking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look closed, but may not be latched. Open the door and close firmly.
Are the shipping bolts removed?
All four shipping bolts must be removed from the rear of the washer before you operate the washer. Each unit is shipped from the factory with four bolts, which are designed to protect the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration, error codes and possible machine damage.
Has a cycle been selected, but Start has not been selected and held for 1 second?
Press and hold Start for 1 second.
Is the Control Locked status light on?
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Is the Delay Wash status light on?
Your washer will start after the selected hours of delay are completed.
Was the door left closed after the last cycle?
The washer door must be opened and closed again to start a new cycle. If the door is not opened between cycles, the washer may not start.
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet has no power
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Front Loading Washer is 14 months old. It is not working properly. The door locks & fills with water. The soap is dispensed. You can hear the motor running but the drum doen Not turn. The alarm...
it sounds like a faulty door switch,when you close the lid,it pushes a switch in letting the washer know its safe to spin,replace the door switch ,it is a common problem as the switch is being pushed constanly open and closed,usally held by 2 screws
Jul 07, 2008 | Samsung Washing Machines
Washer filled up with water when not turned on
The water valve on the washer did not close properly and is leaking past the seal. It is possible that it was a one time event and won't happen again, but most likely you will need to replace the valve. It will probably get worse as time goes on.
They are fairly simple to replace on most washers. If you will post the complete model number of the washer I will try to post instructions on how to repair it. Turn your supply valves off when you are not using the washer until you get it replaced.
Mike
Jan 01, 2008 | Kenmore 4292x Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
82 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
