Question about JVC THD-50 System
Hi How connect my wii through JVCTH-D 50 SYSTEM
I need to connect my wii through JVC TH-D50 to my tv I tried to connect red and white wires from wii to JVC audio in and yellow wire to vedio in. my JVC is connected to panasonic lcd. . when i switch my JVC mode to vedio, i am not able to see Wii. is there a way i cann start my wii through JVC TH D 50
  • 13 Answers
The reason that you cannot see the wii is because the yellow connection on back of th-d50 is an output not an input. you will need to connect the yellow to your tvs input if possible, and leave the red and 9hite for audion on th-d50. if wires are attached together, then you will need to connect your wii directly to tv, and then use a set of red and white cables to connect from audio outt on tv to audio in on jvc unit.
Posted on Apr 17, 2009
  • 44 Answers
Cycle through the AV options and one will work. yellow is the picture, as long as its connected you should be ok.
Posted on Aug 21, 2009
4 Suggested Answers
s4u311
  • 813 Answers
SOURCE: JVC TH-A9
1st u need to covert stereo cable with stereo conversion pin which avelieible in electronic consumer store after u got this cable u able to connect ur speakers directly to play station or a tv
Posted on Feb 19, 2008
  • 298 Answers
SOURCE: I just bought a JVC
See below for the correct setup to get the best clarity sound possible.
From Set top box:
  1. Audio: optical or digital coax cable output --> jvc system Input
  2. Video: hdmi output--> jvc system input
From JVC System:
  1. Video: HDMI output---> TV HDMI input
TV:
  1. only accepting HDMI input from JVC System.
This will provide you will sound from your jvc system at all times. Your JVC system is made to be used as a hub. So essentially what you are trying to do is connect all components into the JVC system. Then only connect the video portion to your TV. The TV itself should NOT be emitting sound.
Note: You may need to turn off the speakers in the TV setup menu to acheive no sound from the TV. This will make for the ultimate experience.
Posted on Apr 03, 2008
SOURCE: NO SOUND From JVC TH-S5 Home cinema system
I know this is an old topic however someone somewhere might benefit from this feedback. I purchased the JVC TH-S5 service manuals from ManualsParadise.com and after metering all the supplies as 'OK', I then focused in on the 'common' lines associated with the two onboard power amps IC's (STK413-400) and found that they were missing a bias supply. This is derived from the onboard 40v Supply 'dropped' down by a 47 ohm resistor R2702 (rated 1/4 watt but advised to make this at least 1/2 watt). The resistor was found to be open circuit i.e. a very high ohmic value. Looking at the circuit diagram again, I would feel that this is going to be a common issue with this unit.
Mike.The.Cork
Posted on Sep 12, 2009
Which cable should be hook up to tv. Trying to hook up DVD player. I have cable with Red, white, yellow.
hi that"s easy thing. first connect rca wire red white yellow to dvd hook up same colour red white & yellow female rca connection. then use another rca wire connect to your tv be video input in yellow one . red & white be sound input - red to red . white to white. just that. good luck!!
Jun 03, 2011 | JVC C-13920 TV
Home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Aug 22, 2008 | JVC THD-50 System
My jvc th s3 DVD player is only playing in black and White how do I solve the problem ?
Sounds like have your component video (RED GREEN BLUE) wires crossed in some way... match them out from the player and into the TV one by one.
Sep 29, 2010 | JVC TH-S3 System
How do I get tv sound thru my TH-D50 srround sound speakers?
your tv needs and audio output if it dosent have one get an old vcr or vvd plaver that does, plug your system to the vcr and vcr to the v. the vcxr needs to be on if you want sound.
Apr 03, 2010 | JVC TH-C50 System
I want to hook up a higth def. cable box to asoround sound jvcTH-M505 with no hdmi,( the cable box does have it )and a samsung 46 in series 6 model 610 lcd. I can get soround sound from the movies from the...
There are a couple of different ways you can do this but this is the easiest.
Items needed - One set of RCA audio cables (Red/White)
1) On the back of your TV there should be RCA plugs marked as "Audio Out". Connect the RCA cable to these connections Red cable to Red connector and White cable to White connector.
2) Locate on the back of the surround sound system the connections marked "Audio in (VCR)". Connect the other end of the RCA cable to this connection Red cable to Red Connector and White cable to White connector.
Now to get the sound to play press the "VCR" button on the surround remote and you should get the cable box sound on the surround system.
Good Luck.....
Jan 19, 2010 | JVC TH-M505 System
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
Connecting an Ipod to JVC TH-M45 System
you can hook up ipod 2 different ways. the one i will use will be with a 3.5 to 3.5 mini plug connection(on both sides of cable it has i.e. head phone jack connection) and then set unit to aux in and that will give you sound from ipod. another way is with red and white audio cables to 3.5 mini plug connection. connect red and white to audio in on back of unit,and then set unit to that source.
Apr 20, 2009 | JVC TH-M45 System
Can i hook my laptop to JVC THD-50
yes its posibble. you need to use a 3.5 mini plug(like your regular headphone connection) to red and white composite(male plugs) cable to connect to back of th-d50.
Feb 19, 2009 | JVC THD-50 System
Cannot get sound from tv to surround sound speakers
you will need to connenct audio cables red and white from audio out on tv or from programming source(cable box sat box) to the audio in on back of jvc unit. then set unit to appropiate source (where you connect cables on back of unit it will be labaled and remote will have button to get to that connection labeled the same) if you want to get digital sound you will need and digital coaxial or fiber optical cable from source(cable box or sat box) and then set unit to video 1 for coaxial and video 2 for optical
Oct 22, 2008 | JVC THD-50 System
JVC TH-S3 System
try to check the av output wire if its properly connected according to its color.
Jul 20, 2008 | JVC TH-S3 System
JVC THD-50 System Logo
495 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
