Question about Sony KDF-E42A10 42 in. LCD Television
Replaced bulb in a kdf-e42a10 and worked for about 8 hours
Replaced the bulb in my kdf-e42a10 and it worked fine for 8 hours and then the bulb blew again. I pulled off the back and checked to see if both fans were working and they are. I received a replacement bulb and am afraid to install it and have the bulb go out on me again. I turn on the TV and the red light blinks 3 times. Any help would be appreciated.
  • 49 Answers
Best thing to do is never use your bare hands to put the bulb in . use a clean paper towel always .the reason is you have oils in your skin and if you touch the bulb you just put oil on bulb.
Posted on Feb 21, 2009
  • 10,594 Answers
3 times red light blinks shows that Lamp Cover is Open. Please put back lamp cover properly.
I would recommend to always replace with Original Sony Lamp and avoid aftermarket or compatible lamps.
Ony KDF- E42A10 lamp needs replaced, should I replace the fan also, just got a new lamp 8 months ago picture is dark
Usually the lamp gets brighter when it begins to fail. I would check to see how dirty the inside of the set is. There are beam splitters and lcd filters in that set and if they get dirty then you lose picture quality.
Nov 18, 2012 | Sony KDF-E42A10 42 in. LCD Television
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
CHANGED THE BULB IN KDF E42A10 AND NOW THE COLOR IS ALL OFF, UNIT WAS UNPLUGGED FOR SEVERAL HOUR WHILE WAITING FOR BULB
Step by Step of what you should do: 1) Get into your car 2) Procced to nearest BestBuy store. 3) (This is where its gets tricky) Ask an Employee where the tvs are. 4) Find the televison of your liking and purchase it. Hope this helps
Dec 23, 2010 | Sony KDF-E42A10 42 in. LCD Television
My parents have a Sony KDF-E42A10 42" LCD TV. They have audio, but no video. Screen is black. Do you think they need a bulb replacement?
Yes, if lamp has not been replaced in last 2-3 years then it is lamp problem. If tv does not shut down and its standby light does not blink in red then lamp is cause of problem, replace it to fix tv issue.
Sep 26, 2010 | Sony KDF-E42A10 42 in. LCD Television
How often to replace the lamp on a tv
lamp needs to be replaced after 3000 working hours or if it got broken.
Jun 20, 2010 | Sony (XL-2400) Projector Lamp for...
Sony KDF-E42A10 42
I replaced the bulb recently on my tv and did not push the bulb all the way in. I had the same issue you are having now, and I was able to get it to work when I realized it had not been installed properly. Make sure you push the bulb in all the way then push down on it so it sets in nice and snug. Sounds like someone replaced the bulb and installed it wrong like I did the first time. Good luck.
Feb 17, 2009 | Sony KDF-E42A10 42 in. LCD Television
Kf42we610
Hi 425hunt
When did you purchase the lamp and how long has it been since it was replaced ?
A lamp normally comes with a warranty of it's own.
I've had a couple cases like yours before.
May 08, 2008 | Sony XL-2100U Projector Lamp for...
Red and Green Lines in TV
The optics block has failed and it will have to be replaced. Contact Sony for an auth. service center in your area as the optics block in this unit has a 2 year mnfg. warranty.
Feb 16, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 42 in. LCD Television Logo
708 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
