Question about Lexmark X2600 InkJet Printer
Lexmark x2600 printer
I just bought this printer i have only printed a couble times it will not print and the orange light by thepower button kees flashing .it won"t print nothing
Pull the tray out at the bottom of the printer. This is causing the printer to think it has a paper jam. It is simply the paper feed button.
Any other issues email me at
Posted on Feb 25, 2009
Lexmark x2600 i have ink and ervything my paper isnt jammed but everytime i try to print the button next to the X button keeps blinking orange
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
2. Open the printer cover and remove both the cartridges.
3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check the light status.
8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
10. Load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 21, 2011 | Lexmark X2600 InkJet Printer
I installed new ink cartridges in my Lexmark X2600 printer. Print quality is faded. Cleaned cartridges twice. Print quality is still light. How do I fix this?
Go into printer properties and make sure that you don't have print quality set to draft. Try normal or best and see if that makes any difference.
Feb 20, 2011 | Lexmark X2600 InkJet Printer
I have a lexmark printer, and every single time I click on print, "Print the alignment page" I do not know how to fix it.
Click Start
Click Control Panel
Double-click Printers
Right-mouse click on your X2600
Choose Properties or Printing Preferences
Look through the menus, for the "Print the Alignment Page" function.
Click to start the process.
Follow the on-screen instructions.
Feb 01, 2011 | Lexmark X2600 InkJet Printer
Can i wirelessly connect my Lexmark X2600 printer to my Toshiba Laptop
I regret to inform you that the Lexmark X2600 is a USB based printer, however, you can use a wireless print server to turn this printer into a wireless one. You can check the internet on how wireless print servers work. Thanks.
Aug 11, 2010 | Lexmark X2600 InkJet Printer
What are proceedures for replacing print cartridges for Lexmark X2600 ink jet printer?
Perhaps the Lexmark X2600 User's Guide will be able to help you. To download it, click on this link: Scroll to Removing used print cartridges, Page 45, for instructions on how to replace print cartridges.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps.
Jun 11, 2010 | Lexmark X2600 InkJet Printer
Printer is not printing - i have started, restarted diagnosis tests, changed the ink, uninstall and installed program. I have a Lexmark X2600. It says that it's ready; but still doesn't print? what else...
Check the USB cable to make sure it is connected, then restart your computer. Sometimes the computer registers it on a different USB port. When you go to print look at your printer options, is there a Lexmark and a Lexmark (copy 1)? Try printing from Lexmark (copy 1) if it is showing. If there is still a problem, try putting the print on another computer, to see if the printer is malfunctioning. If that is the case, you'll need to get another printer.
Sep 14, 2009 | Lexmark X2600 InkJet Printer
Problem with cartriges
EC5 = Print Head Short. Short test detected short circuit in printhead. Fix is to replace print cartridge(s).
Sounds like one or both of your new cartridges are defective and need to be returned to where you purchased them.
Mar 02, 2009 | Lexmark X2600 InkJet Printer
Only prints one page at a time
The driver could be corrupted or it is set to default to one page only.
When you bring up the printer's menu, check the setting for the number of pages; it should default to 'All.'
If you find nothing misset, try reinstalling the software that came with the unit.
If it argues with you because it has detected an existing installation, then remove the Lexmark software through the Control Panel, 'Add or remove programs' function. If you have to go that route, then remove that printer from the 'Printers and faxes' folder, reboot with the printer turned on and if asked for a CD, insert the one that came with your Lexmark.
Jan 14, 2009 | Lexmark X2600 InkJet Printer
Cant install lexmark x2600 on windows vista
You need to install the Vista version. Goto this site-download the driver-install-enjoy!!
Dec 17, 2008 | Lexmark X2500 All-In-One Printer
Lexmark X2600 InkJet Printer Logo
334 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
