Question about Dell Dimension 3100 PC Desktop
Slow Wireless I have high speed internet, a router and a USB, but it's really really slow. I was told that because my computer was 4 years old a pci card would make things faster?
  • 447 Answers
I'll assume from the wording of your question that you are using a USB wireless adapter.For the most part you get better performance out of a PCI wireless card (and better range) but you should also run a scan and clean with this program to make sure that your performance issues aren't due to spyware or malware also.
Posted on Feb 21, 2009
Does my wireless router need to be on internet to stop the video freezing while on skype
This is a 14 year old router and runs at a very slow speed.
It will not support video with todays high resolution cameras. Probably time to upgrade to a 802.11G router.
Apr 29, 2014 | NetGear WGR614 Wireless Router
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Dynex DX-E102 PCI co/100Mb Network Adaptor provides really slow connection to my Dell Dimension 8200 PC. How can I speed it up?
speed is a function of line of sight distance so measure distance from wireless router for pc and then open that utililty on pc and see what relative speed is happening
if the signal is less than 3 bars, that is like a wireless tach
need at least 3 to 5 bars to get speed
also, your pc has a network adapter card no doubt might be that it's running a full tilt and needs an upgrade
let me know what you find
May 31, 2012 | Dynex Computers & Internet
My down load is very slow
Hi,just check your speed from here http://www.scanmyspeed.com/ and if still your speed continues to be slow contact your provider.
Mar 08, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Range on the wifi
Need more info, but it could be a number of things. Many thing affect your wireless speed:
-Walls
-Distance
-Other wireless devices, or devices that emit radiation (Microwaves, cordless phones, baby monitors and etc.)
Other things could be:
-your computer is just plain slow
-there are too many people connected to the wireless at the same time
-your internet connection is slow either in general, or just temporarily
More advanced (and unlikely) reasons:
-your network adapter has been forced to operate at a slower speed
-your router is set to operate at a slower speed in its configurations
Apr 03, 2010 | Linksys WRT160N Wireless Router
The internet speeds to the wireless unit keeps going really slow if you reboot everything it works for a while thens slows to a crawl again
Ask you Internet Service Provider regarding this problem. Definitely, it is not a problem from your end like your software or router. It in a slow internet connection from your ISP.
Nov 30, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
7 years old Dell loading slowly
Increase your RAM meory so it speeds up fast.
Also scan your computer with antivirus .
Jul 13, 2009 | Computers & Internet
Wireless computers work fine, wired desktop extremely slow
On your old desktop, go to Control Panel > Internet Options > Connections > LAN Settings make sure no check on boxes there. Click OK and Apply. Click on General tab, click on Delete File (delete all offline content), Clear History and Delete Cookies. Click Apply and OK.
Jun 29, 2009 | Linksys Wireless-G WRT54G Router
My Computer is going toooooooo slow !!!!!!!!!!!!
theres a million things that can interfer with wireless...tin...cell phones, cordless phones and the like..but 11mbps is still really fast and chances are, your internet connection isnt even half that so your speed on the net shouldnt be effected...1mbps is usualy enough to load any website in seconds.
if your PC is slow, not jsut on the internet but in general (starting up, running apps) then its an issue with the pc and not the wireless.
but as a heads up, not trying to be mean, but netgear and belkin are cheap equipment.
Apr 26, 2009 | NetGear WGR614 Wireless Router
Slow Download Speed and Computer Wont Recognise The Hardware Sometimes
I wondered wat USB version ya had? Is it Version One? or Two?, as USB1 is real slow... and MOST things these days need USB2 to function... As w work around I sometimes use is an after market internal PCI USB 2 card, that gives ya USB 2 & Firewire too if ya want..
Aug 23, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Dell Dimension 3100 PC Desktop Logo
61 people viewed this question
Alun Cox
