Question about Maytag Neptune MDE5500AY Electric Dryer
Load squeal The dryer is squealing from the time we start all the way through drying cycle. The drum spins okay and dries, the squeal is almost unbearable
  • 1 more comment
  • takahomsak Feb 21, 2009
    My dryer is doing the same thing........started making the squeal just occasionally, now does it almost every time used. Cannot yet afford to get a repair person out, and hoping someone has a do-it-yourself solution or ideas on this.
    CindyT.....
  • dane dang Mar 05, 2009
    I have the same loud squeaking/squealing problem with my dryer, it's during the entire cycle. Impossible for me to figure out how to even clean all the lint that has fallen down in the door, as there seems to be no way to open it to get to the lint. Called in a professional to make sure I don't create a "fire hazard" for future uses.
  • Anonymous Mar 14, 2014
    dryer squeals but dries fine
  • 686 Answers
If you can take your dryer apart, you'll have to take the drum out and lubricate the bearing that is located in the center under the drum while there check wellness of your heat element if located there. Anyway use high temp grease on this bearing looks more like a ball
Posted on Feb 23, 2009
Squeals while drying clothescould this be a bad belt ?
It can come from two things, belt for sure when you over load the dryer or it is getting worn an second the rubber wheels the drum sets on can squeal.
Mar 29, 2014 | Kenmore Elite HE4 Electric Dryer
Maytag electric dryer drum starts and stops turning but keeps going
I would think you are on the right track, possibly a belt, I would also check all the rollers or idlers while you are replacing the belt.
Enjoy and best wishes
Dec 20, 2011 | Maytag Dryers
Squealing sound during spin cycle
Hi, the squealing could be a result of a loose or slack belt or dry bearings, try replacing the belt to see if this cures the problem.
hope this helps.
Feb 13, 2011 | Kenmore 88732 Top Load Stacked Washer /...
My dryer is squealing
Check the outlet is not blocked, also nothing jammed inside the drum, also the main bearing.
Mar 25, 2010 | Dryers
Our front load fridgidare dryer has began to squeal
You need a rear bearing most likely (5303281153)
This kit includes all that you need to redo the drum bearing. I have repair photos HERE
Mar 08, 2010 | Dryers
Washer squeals in rinse or spin
When the washer is in the final spin cycle and starts to sqeal, just pour a little water through the drawer about half of a glass full usually does the trick. What apparantly happens is that the connection/seal between the big grey rubber seal and the stainless steel drum has dried out due to the centrifugal effect of the spin cycle and it needs to be wetted to keep the sealed area lubricated and cool. The squealing is a result of the dry rubbing of these parts during the spin cycle.
Apr 17, 2009 | Washing Machines
Dryer squeals off on during the cycle
The rear drum support must be replaced.
Part number 5303281153
Nov 29, 2008 | Frigidaire GLGH1642DS Front Load Stacked...
Dryer Squeals
my sears kenmore 417 stacking get things caught every time in the dryer and leaves some brown stuff on all my clothes.
How can I keep things from getting caught??
Jul 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
228 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
