Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag mce8000ayw start button won't work
I have a Maytag dryer with drying cabinet that won't start. All the lights on the front work the upper unit works, but when I push the start button on the lower unit it does nothing. All the other buttons on the lower unit do just as they are supposed to. Can you give me an idea of what needs to be replaced?
thank you
  • Anonymous Apr 15, 2009
    I have the exact same problem. Email me at chadwick07@aol.com if you found a solution.
  • wkgrisham May 04, 2009
    I have the same problem plus my off button has gone out - both for the lower dryer only. Problem is that the control panel is all one piece and the replacement part is more than $320 every place I have found it online.
  • 686 Answers
Your starter button needs checked at least but most likely replacded
Posted on Feb 23, 2009
MAYTAG NEPTUNE DC MOD# MCE8000AYW
Your exhaust is gettting restricted and not able to remove the moisture from the clothes. Also check lint screen with very slow flow of water. If water rolls off wash filter good .. If water can't pass through smoothly then air is also having problem being pulled through as well.
Nov 15, 2016 | Maytag Dryers
May tag mce8000ayw start button doesn't work.
no you need to replace the hole thing whach is called Console W/membrane Pad part number 31001658
it may cost about 200.00
Jan 30, 2013 | Dryers
All the lights are lighting up but when I hit thew start button i hear a click but nothing happens. Maytag Neptune Model# MCE8000AYW
If there's lint or a problem with the air passing thru and evacuating, the sensor within the system will not turn on the gas or energy to begin drying. Time for a service call.
Oct 08, 2010 | Maytag Dryers
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Dryer makes noise like a bird chirpping.
You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Problem with upper cabinent of Maytag Drying Center.
Mine did same thing within warranty. There is a motherboard problem in them that is cause by power surge during an eletrical storm. First try unplugging for 10 minutes and see if it resets. If that doesn't work, you need to have the motherboard replaced that runs the unit.
Repair man took the front off my unit and replaced entire motherboard. He stated that it was a known issue with that motherboard. I have had no problems since my motherboard was replaced 18 months ago.
Dec 02, 2007 | Maytag Neptune MCE8000AY Electric Dryer
Squeeking in lower dryer
remove the rear panel. unplug dryer before doing anything
Oct 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
546 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
