Question about Bodum Granos 3020-16 Espresso Machine
Parts for the Bodum Granos Espresso Machine
Looking for a supplier of internal parts for the Bodum Granos machine, or a repair place within the tri-state area.  I need to replace the solenoid valve in the machine.  Any info would be greatly appreciated.
  • ezliving Feb 23, 2009
    Need Repair Service anywhere in US.. Lights flash three times but will not heat. Steam and Hot water lights flash, but does not heat.
    Bodum discontinued this unit and no longer provides service.
    I was able to get it to work for a short time by "priming" the water valve by removing and replacing the water tower.. (noticed bubles each time I replaced the tower until it was primed)
    Now it will not come on at all..??
    Jim
  • ezliving May 11, 2010
    Adaric,
    Thanks for that info.. actually I have done that and now have my new machine, but....
    I am concerned that since they have discontinued this model, if this or another problem pops up.. "Who" can I find to repair my machine, and I will pay for the cost.
    Thanks again.
If you have a receipt, there is a 2 year warranty on the machine. Bodum will replace it with a new one.
Posted on Mar 24, 2009
    New Friend:
Did you find a parts supplier? I need a new control panel for mine.
Posted on Nov 12, 2014
How could I fix my machine?
Refer your inquiry and description to Bodum.
May 01, 2014 | Bodum GRANOS (3020-16US) Espresso Machine
Leak around brew head
Have same problem. Have you had any luck in solving this problem?
Sep 23, 2012 | Bodum Granos 3020-16 Espresso Machine
Im looking for the operating manual for a Bodum Granos coffee machine please
you can obtain your manual by clicking on this site and following the links to download the manual http://www.retrevo.com/support/Bodum-3020-Granos-Coffee-Makers-manual/id/4610dj094/t/2/ or to bring you a step ahead to the following page click this link
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
this site is free to download any manual or instructions and if you have any problems obtaining it through this site message me back along with your email and I will send it to you from my email. Please also remember when our chat has fully concluded to rate how this service has helped in locating your manual for you. By doing this it allows me to continue helping others in similar situations in the future.
Thank you
Rick
Jan 17, 2012 | Bodum Granos 3020-16 Espresso Machine
Hi i have bodum grandos espresso, i need a new group head and water tank where can i find in Sydney?
Hi I have the same machine that has been taken apart and so it's now a pile of spare parts. When you say new group head, do you mean the collar of the group head, or do you need a new group handle and basket ? I live in Sydney if you want to get in touch.
Mar 25, 2011 | Bodum GRANOS (3020-16US) Espresso Machine
My bodum granos expresso machine leaks from the base. would anybody know why. If not is there somewhere I can send it to be fixed in Canada? Thank you:)
Did you find an answer for this? mine is brand new and leaks from the base. I know its been on the shelf at the shop for 3 years, so I'm expecting its a leaky seal somewhere.
Mar 22, 2011 | Bodum Granos 3020-16 Espresso Machine
All the lamps on the Granos flashes - what does it
Clean it with CLR. I had to turn the steam on and plug and unplug it to get it to work for just a few seconds but that was enough to get some of the CLR into the system. I let it sit overnight and then the next day it would work for 10 - 15 seconds at a time. Finally the more CLR I got into the system the better it worked. I regularly used a coffee maker cleaner but the CLR seemed to break up whatever was in there.
Jan 07, 2010 | Bodum GRANOS (3020-16US) Espresso Machine
Pump activates put coffee does not drip instead it water comes out the top of the pod handle
I had the exact same problem about a year ago. I bought a replacement valve from Bodum here in Denmark, where I live.
The cracked valve was made out of some sort of plastic, but the new one I got was cast in metal.
The machine has been working perfectly since.
Oct 07, 2009 | Bodum Granos 3020-16 Espresso Machine
Bodum granos new will not function
the connections to the heating coil element looks faulty.check it.
Jan 18, 2009 | Bodum Granos 3020-16 Espresso Machine
Bodum Granos 3020 Espressoo Machine
Last year I stripped the machine and found the blockage in a diverter valve. This device switches between the coffee making head or the steamer. I had a blockage in the diverter causing the solenoid to lock in the coffee position that was also blocked. I flushed the system out with Oust cleaner.(very quick and effective) I then reassembled the machine and put sachet of oust with four times as much of filtered water. Then I switched the machine on and passed half the through the coffe head and steamer at full heat. Left for 10mins. then passing the rest through, cleaned with filtered water and away it went. Fixed!!! email gethudall@hotmail.com
Feb 18, 2008 | Bodum Granos 3020-16 Espresso Machine
This is not a fix but it may be a way to at least get an espresso without milk. I opened the panel on the back and removed the to wires at the top of the circut panel. They are both fixed to a plug so all you have to do is gently pull. This turned of the steam/water function and the the water came through the head as it is suppose to. I did not get all the parts with mine so if anyone tries this please post the outcome. Remember to unplug the machine before you open the back. I will post the real fix if I figure it out.
Oct 26, 2007 | Bodum Granos 3020-16 Espresso Machine
Bodum Granos 3020-16 Espresso Machine Logo
2,241 people viewed this question
Top Bodum Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Peter Meixler
Peter Meixler
Level 1 Expert
ray gallant
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
