Question about Canon PIXMA MP150 All-In-One InkJet Printer
Vista for canon pixma mp140
I installed vista ultimate and then refilled for the first time my canon pixma mp140 catridges color prints showing plenty of lines is it anything to do with vista or is it something else
  • rams reddy Feb 22, 2009
    buddy  i asked about canon pixma mp140 not about mp530
    Novelist:
  • 103 Answers
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontavista for canon pixma mp140 - align_compare.jpgbr />align_compare.jpg
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with thevista for canon pixma mp140 - mp500_alignment_manual_3.jpgk
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Posted on Feb 21, 2009
2 Suggested Answers
fotobean
  • 103 Answers
SOURCE: colr prints showing plenty of lines
Here's a solution from Canon USA:
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <2> Example of the pattern with the most visible vertical streak
Hope this helps - fotobean.
Printing turns green
Your color i.e. Yellow & Cyan were functioned well but Your Color i.e. Magenta is not functioned will.. so remove the catridge and refill the Magenda and after refilling rub the catridge head with a soft paper untill the magenta is over flow.. after that your printer will print better. .. thanks
Aug 26, 2011 | Canon Pixma MP500 All-In-One InkJet...
I refilled both black and color ink catridges and after doing it plenty of lines are coming in the picture print outs even though letters appear good when i take black only .i did deep cleaning also .print...
insert your'e (prob. clogged) cartridge head surface into hot water for about 30 seconds. Then test the cart. over a paper tissue. If you see all colors test it on printer. If not you prob. need to vaccum the head. If all fails, replace cart.
good luck
Nov 05, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My Canon Pixma IP1980 print has lines and color is not even, to much green.
I have refilled my canon iP 1980 printer catridges and I am currently encountering 2 problems:
a) The notification telling me that the ink is running low wil not dissapear.
b) There are lines across my documents when I print them. Those lines resemble those that occur when the ink is running out. however, I have already refilled it twice and am quite sure that the catridge is now full.
Please help--your advise will be greatly appreciated.
Jun 09, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Ink, copying and printing problems
canon MP 150 Series printer usB001
The waste ink absorber is full
May 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Catridge problem
when printing try to press resume button for about 5 seconds
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I recently refilled my canon pixma mp140 catridges but printout (colour) shows plenty of lines black and white no problem
Please visit the following site: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=15294#SupportDetailAct
This will clarify what you need to do - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixma refill is not recognized
Dear nedaa,
You need to deactivate ink level detection function to keep your printer working after refilling the cartridge. Click here to know more how to deactivate ink level detection function.
Source:
Canon Inkjet Printer Forum
Canon Manual & Tools Dowload
Jan 17, 2009 | Epson Stylus 2200 InkJet Photo Printer
Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Aug 28, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
Apr 17, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
1,174 people viewed this question
old marine
old marine
