Question about Canon PIXMA MX310 All-In-One Printer
Hooking up mx310 all in one
How to hook up all in one when you have dsl/broadban modem, every time I put it on the splitter and hook fax phone line in I cant get on the internet, even tried another filter from the splitter and it still knocks me off the internet
  • 447 Answers
The phone line should plug directly into the Line plug on the DSL modem and the all-in-one should plug into the Phone plug next to it. If you need to split the line do it AFTER the line comes out of the Phone plug.
Posted on Feb 21, 2009
How do I hook up my fax machine with a cable modem connection only
If it is a DSL modem, use a DSL splitter / filter. The fax machine should be connected the tel port.
Sep 09, 2014 | Brother FAX-575 Personal Plain Paper Fax,...
How do i hook up phone line to dsl??
You need to connect the phone line to the DSL splitter... From the DSL splitter you will have 2 RJ11ports. one should be connected to the telephone and another should be connected to the modem....
Jan 28, 2011 | 2wire Computers & Internet
Modem
Your connections are screwed up. Call your cable company for help in getting you straightened out.
Apr 24, 2017 | Telebit Refurbished OPEN BOX EXTERNAL...
When my phone rings the kids get booted off xbox live and i have wireless internet and wireless adapter for xbox360
Hi Jeannie,
Based on your problem I assume that you have DSL. When you get hooked up for DSL they send filters that you are supposed to put between EVERY phone and the jack. (Don't forget phone lines for satellite and alarm systems).
If your dsl drops every time the phone rings, there are usually 2 things that cause this.
1) A bad filter in your house. If a filter is bad or missing it can cause the dsl to drop either when the phone rings or if someone picks up the phone with the bad filter.
2) The other reason could be on your ISP's side. It's called a POTS splitter. You have one of these if you have BOTH phone and DSL. It's what sort of combines the 2 together. There are a number of problems that can occur with a bad pots splitter. i.e. DSL works - phone totally dead, Phone works-dsl - totally dead, disconnects, etc...
I suggest that you hook up the dsl modem by itself. DISCONNECT ALL PHONES IN THE HOUSE. Do NOT have anything connected at all except the dsl modem. No filters, phones, directv, digital cable, or anything else in a phone jack. Then when you are up and surfing, take your cell phone and call your house. Technically it should just ring and ring. Unless you have voice mail in which case it will go to voice mail after so many rings. Anyway, see if when the line is ringing in your cell phone if it is dropping you off. If it DOESN'T, then it's probably one of the filters, jacks, or wiring. If it still disconnects, it's probably the POTS splitter with your ISP.
Good luck and if this helped please help me out and leave feedback!
Thanks!
Feb 08, 2010 | Computers & Internet
How to connect the telephone lines
Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
i.e is fax line ) or the usb port in the computer ...
Good luck...
Feb 02, 2009 | RCA 25201RE1 Corded Phone
I can't hook up the way it says to
Fax machines need an RJ-11 phone cord and are ANALOG
DSL uses RJ-45 and is DIGITAL.
Don't waste your money on a DSL filter, they won't work reliably.
Dec 16, 2008 | Office Equipment & Supplies
No filter
There you go. Stop by Radio Shack and pick up a DSL filter and hook it up to the wall outlet of your fax machine. If the DSL modem is next to your fax machine, plug the fax machine into the outlet marked as phone.
I just got done doing this to both of my offices. Typically the phone company will use your fax line to piggyback the DSL. All you have to do is make sure your DSL modem output goes to the fax line either through the wiring block in your office or directly to the back of the modem itself.
That way you won't need the filter.
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Problem connectine fax line to...
First of all what type of phone line r u using ....is it a normal phone leine or DSL....
IF u have a DSL...u need to have a splitter...
If u have normal phone line then connect it directly to printer in the line jack...and from Ext jack to phone...
Check if get on hook dail...ie..see if u can hear the dial tone...
Try sending a fax and if u get a msg "fax Complete " then its working
Jun 20, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lemark 5400 can't faxor rec fax give phon lone error message
If u have DSL modem ..u need to have a splitter for the fone line.....and then....the connections need to be right...
Phone line to splitter -splitter to Fax mech(Line Jack)...
Problem Receiving--
Make sure ur answering Mech rings are set more than the fax mech...i.e (if ur answering mech is set to 3 then fax mech should be set to 4)....
If u r using DRPD(distingtive ring pattern i.e If u have one line and two numbers.....) then set double ring for fax and single for Phone or answering mech....or vice versa...
Jun 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
Connecting
jon, I am assuming you have DSL modem. Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. Good Luck, Tim
Feb 03, 2007 | Lexmark X4270 All-In-One InkJet Printer
Canon PIXMA MX310 All-In-One Printer Logo
106 people viewed this question
old marine
old marine
