Nordyne electric furnace heats up but fan won't come on when set to auto. Is it a relay switch. Have installed a new thermostat.
  • ptricia325 Feb 28, 2009
    the t-stat has been installed for a while. Asked the question at www.mobilehomerepair.com, and was told it was a bad sequencer. Don't know which one to get. Thanks for any help.
  • bsblevins Mar 02, 2009
    i have same problem but i didnt install new t-stat we have to turn breaker off then back on for it to start working please advise if you have answer thank you
  • 3,361 Answers
If the fan runs in the ON setting then you have a bad fan relay for the heat mode.
Did you install the t-stat before or after the problem?
If after, you have a bad fan relay.
Posted on Feb 21, 2009
  • steve
    steve Feb 28, 2009
    Is this gas or electric heat?
    Is this a digital thermostat?
    If digital did you select the correct type heat setting on the t-stat?
2 Suggested Answers
meBNme
  • 334 Answers
SOURCE: Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Posted on Mar 06, 2009
My unit is a Honeywell and not a Muirfield.97-4118/5-89 and it will not work on auto but works on manual.
If it's a new thermostat that you have recently installed, check your installer configuration. Make sure the tstat is set up for gas or electric heat, depending on what you have. Some t-stats also have a small switch on the back to switch from gas to elec. A gas furnace has components to control the fan, electric unit uses the tstat to control the fan. Hope this helps!
Mar 21, 2017 | Honeywell Heating & Cooling
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Fan will not come on when it's set in auto mode
If your thermostat is being used with an electric heating system and the fan does not start in heating mode on auto; remove the thermostat from the subcase on the wall and check for a switch on the back of the thermostat. A lot of electronic thermostats have a switch on the back that says electric/heat pump and gas/oil. If you have electric heat or heat pump you need to switch it to this side. Usually this is set at the factory for gas/ oil. Gas/oil furnaces have built in means of bringing on the fan and electric/ heat pumps are brought on by the thermostat.
Feb 11, 2015 | Hunter Fan Company 42999B - Heat/Cool...
I have a Nordyne furnance when the temp is reached and the heat turns off the fan keeps running
On my thermostat for the furnace there is a switch for FAN - Auto On. When switched to On it runs constantly.
Feb 11, 2015 | Heating & Cooling
No fan when ac kicks on Ihave a eb15b funace with a coleman ac
The heat will normally use a low speed on the fan, & the AC along with the fan switch on the thermostat will use the high speed. The thermostat turns that high speed on when there is a call for cooling & is the same switch if you were to manually turn the fan from auto to on. Try turning the fan on @ the thermostat. If it works, then replace your thermostat. If it doesn't, it could be a bad fan speed, a bad fan relay on a control board or external relay, or a loose or broken green thermostat wire.
Apr 14, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
I have a Goodman GU100 furnace/air handler. Gas fired and combination heat/air cond. The furnace fan would not run on auto, but the burner came on. I changed the thermostat, but same problem. I have...
if you have a wire on the g terminal you should set the tstat to electric heat not gas in the configuration. or a dip switch on the back of the stat.
Nov 26, 2017 | Goodman Heating & Cooling
I have an intertherm electric furnace FEH-A020, with multispeed blower installed when A/C added. My problem is blower operation. at the end of the cooling season with fan set to auto operation the fan ran...
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
Oct 17, 2009 | Intertherm P3RA-048K Air Conditioner
Feb 28, 2009 | Heating & Cooling
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
368 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
