Question about Mitsubishi M-VR600 Receiver
Cant program my receiver to a dish network remote for lack of device code. Device codes are listed for 28 tuner/amplifier makes and I have tryed them all. Contacted Mitsubishi and Dish network for code and no help.
5 Suggested Answers
cammykins
  • 149 Answers
SOURCE: lost my picture when went to pip
Check your PIP source. I couldnt figure out my LCD pip, and why it wasnt working either until I was able to switch the source. It was automatically using a source that didnt have anything hooked up to, I had to switch mine in order for it to work. Try that and see if that might be the case. let me know. thanks!
Posted on Sep 24, 2007
  • 1153 Answers
SOURCE: WS-55809 HD1080
Nothing but a HD signal!
Posted on Nov 30, 2007
  • 7 Answers
SOURCE: HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Posted on Jul 19, 2008
SOURCE: Xbox 360 or Dish ViP 622
when i hook either my dish hd receiver up to the 1080i component video inputs, everything works fine if i set either device to 480p, but i get nothing i set them to 1080i.
Posted on Jan 27, 2009
  • 4 Answers
SOURCE: Problem with device menu & remote
Remove the front trim plate below the manual switches, may have to remove the speaker covers to access this area, remove the switch mounting plate 3 screws, turn switches over and unplug the little white electrical connection for the switches. TV should work perfect with the remote now. Not sure what is wrong with the switches just yet, but suspect a resistor problem.
Posted on May 18, 2009
Tip
DISH VIP612 Program AUX Remote Code 2
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Can you change the remote control code on a Dish Network VIP612 dvr receiver? Any way to change remote address in the receiver so it works on remote 1 and is compatible with Harmony 650 remote???
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Sep 27, 2016 | DISH Network ViP 612
Trying to program dish network remote to sony str de 445 amp;
We would be happy to help with that. Here is a list of some of the codes that we have for Sony Amplifiers: 500, 645, 687, 639, 846, and 765.
Press and hold the AUX mode button until all mode buttons at the top of the remote come on, then release. Enter the number 2 then * then one of the codes for your Sony amplifier provided above.Press the pound (#) button, the mode light should flash three times. Check that the code works by trying severaldifferent functions on the remote to make sure it will properly operate your Sony amplifier.Keep in mind that some codes may not be compatible with your equipment. If thisis the case, please try the other codes listed for that device until you findone that is compatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
Aug 01, 2010 | Sony STR-DE445 Receiver
Tip
DISH VIP612 Remote Code Scan
Would you like to autoscan program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To auto-program device codes into your Dish Solo DVR VIP 612 Universal Remote by searching for the code, follow these steps:
  2. Press and hold the mode (TV, VCR, or AUX) button until all the other buttons light up, and then let go. The mode button will flash.
  3. FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner. Then press the STAR (*) button.
  4. Press POWER to put your remote into scan mode.
  5. Press the UP or DOWN ARROW repeatedly until your device turns off. Each arrow press tries the next code your remote knows for your selected device type. When your device turns off, you have found a compatible code. When the remote runs out of codes to try, the device will flash rapidly eight times.
  6. Press POUND (#). The mode button will flash three times as it stores the found code.
  7. Turn the device back on and try some of the other buttons to make sure they work. If all functions work, your remote has been successfully programmed.
  8. If the code didn't work, repeat this scanning procedure to find a more compatible code. When your device turns off during your next scan, press the arrow key again until the device turns back on to signify you have found the next compatible code.
Your device's remote control codes for your TV, VCR, or receiver are now programmed into your DISH Solo DVR ViP 612 remote control.
(The other way to program your DISH Solo DVR ViP 612 remote control is to look at the tables in back of the user manual, and enter the code directly.)
I hope that helps.
Tip
DISH VIP612 Amplifier Control
DISH Solo DVR VIP612 Amplifier / Receiver Control
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control the volume of your receiver, tuner, or stereo instead of your TV's volume?
The first step in using the Universal Remote Control that came with your Dish Solo DVR VIP 612 to control the volume level of your receiver, tuner, or stereo is to program the remote to control your audio device using the AUX mode button.
Once your remote controls your audio device in AUX mode, you probably want to continue to control the volume of your stereo even if the remote is in SAT, TV or VCR mode.
To setup your Dish Solo DVR VIP 612 Universal Remote to control the volume of your stereo regardless of which mode it is in, follow these steps:
  1. Press and hold the AUX button until all the mode buttons are lit, and then let it go.
  2. Press the POUND (#) button.
  3. Press the PLUS side of the VOLUME button.
  4. Press 0.
  5. Press the POUND (#) button. The AUX button flashes three times to tell you the programming is complete.
  6. Confirm the VOLUME buttons are operating the tuner/amplifier's volume control by pressing SAT or TV, and then adjusting the volume. Your tuner/amplifier's volume should change rather than your TV's volume.
Your Dish Solo DVR VIP 612 Universal Remote is now setup to control the volume of your stereo regardless of which mode it is in
I hope that helps.
What universal code to use with the VR-615 on dish network remote
We would be happy to help with that. Here is a list of someof the codes that we have for your Kenwood Receiver: 774, 795, 668, 691, 728, and 745.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Kenwood Receiver provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Kenwood Receiver. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
Phillip Chang
May 13, 2010 | Kenwood VR615 Receiver
Tip
  4. Press 0.
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
Tip
I hope that helps.
Tip
I hope that helps.
Tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
375 people viewed this question
Top Mitsubishi Audio Players & Recorders Experts
ruggeg
Todd Arndt
Todd Arndt
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
