Question about Vehicle Parts & Accessories
Mgf central locking won't open the car doors
When you press the key fob or use the key the cental locking opens the immediately locks the doors so i cant get in. I have managed to open the passenger door with a piece of wire to pull up the locking mech. but the drivers side sems to be dead locked
  • Anonymous Feb 28, 2009
    How did you opened the passengers door?¿ I have the same problem but only in the passenger's door.
  • carol profeiro
    carol profeiro Jan 02, 2014
    with the keys and not the buttons on the keys.
I had same problem. It was cured by "flicking" shut the interior opening handle of the drivers door. This allowed the central locking to lock then unlock the drivers door properly. You get into the car in the first place by using the romote to "unlock" and whipping the passenger door open quickly before it has a chance to relock!
Posted on Aug 13, 2009
  • pwk529 Jan 25, 2011
    thanks for that mate,i had tried everything i was just about to strip the door panel so glad i logged on well done phil keating maghull liverpool 25 01 2011
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Skoda ovtavia fob only opens drivers door
Check your car setup. Read the manual on MAXI DOT and look for Main Menu > Settings > Comfort > Central Locking. Within the Comfort menu you can also reset to factory which should set central locking to automatic.
I hope this helps.
Mar 09, 2014 | Skoda Octavia Cars & Trucks
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
Central locking working passenger door won't open
get remote checked wires might need re soldering or replace remote with new one. Cheapest place to purchase one is at a key cutting place or lock retailer.
Jun 12, 2012 | 2006 Seat Ibiza 1.4
I have a renault megane 1998, central locking suddenly stopped working tested key fob thats OK
It could be your onboard computer or locking module, as the guy next door had an identical problem on his Megane. A tech came and changed a module then programmed the 'brains'.
Oct 29, 2017 | Renault 181 Cars & Trucks
Toyota corolla verso 2007 . the central locking has stopped working
Toyota Corolla Verso - Central locking has just stopped responding
So you don't waste your time, here are some assumptions: -
1. When I press the key fob there is no sound of doors trying to lock/unlock and I know the key fob is fine.
Solution:
In this situation reset the alarm/locking system
Below is the procedure I followed to get the central locking working again: -
Open the passenger door, and look at the side of the dash board. There should be a triangular panel. Pull the panel off to reveal a small set of fuses(see the back of the panel for the fuse map). To power down the central locking you need to remove the Dome Light fuse, this is located top left. Second one down 7.5 amps. (if in doubt remove the top two 7.5 amp fuses I did)
When you remove the fuse(s) you will notice the interior light go out indicating you have powered down the system.
Now leave them out for at least 30 mins so any capacitors can discharge properly. (Be aware while the fuse is removed all central locking is disabled, so the other doors are open. I left the fuse(s) out over night with all the doors open but I don't recommend it, 30 mins should be fine)
After 30 mins replace the fuse(s) close all doors, and then try your key fob, hopefully you should here that satisfying locking sound.
2. When I press the key fob I hear the locking system trying to engage.
This could be a faulty door switch on any door including the boot, or there could be a dent in the inner door panel of any of the doors, usualy the rear doors due to the seat belt not retracting properly.
Solution:
Check all door switches for damage, and check inner panel for dents, just a small dent where the switch connects can be enough to not engage the switch. This will stop the central locking.
Use some kitchen roll wrapped in tape (as a makeshift pad) and tape to the inner door as a temp measure to engage the door switch. At least you can then lock the car.
Jan 04, 2011 | 2007 Toyota Corolla
Central locking
turn key twice when opening, ie turn right. once drivers door will unlock, turn twice passengers doors will unlock, and locking is turn anti clock wise once will lock all doors, turn twice will set door dead locks.dead locks will stop openand lock internal button working and handle from opening door. the same actions can be applied to the remote one press drivers door, two press passenger doors, press and hold unlock button for 5 seconds and rear window will open.
Apr 23, 2010 | 2003 Land Rover Freelander
1997 Porsche Carrera S --- Central Locking System Battery went dead while on travel and now the key fob for central locking is kaput! Is there a sequence to re-sync the fob to controller?
Maybe you can try this procedure to resyn your key.
Initialization Procedure.
1. Open central locking system using the car key.
2. Get into the car and close all doors.
3. Using the car key, switch the ignition lock briefly to position "1" and then switch off again. (Please do this switching within 5 seconds or otherwise the system is not ready for initialization.
4. At the remote control key. Press the "OPEN" key (->) and keep holding.
5. When holding the "OPEN" key, press the "LOCK" button three time.
6. After pressing the "LOCK" button 3 times, release the "OPEN" button.
7. If the initialization process is sucessful, the door will lock and unlock immediately to confirm the process.
Jun 05, 2009 | 1997 Porsche 911
Ford fiesta ghia 1998 model central locking key
This is a common problem after changing the Key Fob battery.
The solution is to remove the fuse feeding the Cental Locking for 10 minute...Replace then all should work fine
Nov 30, 2008 | Code-Alarm Code Alarm Transponder
Vehicle Parts & Accessories Logo
1,390 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
