Question about Kenwood VR-405 Receiver
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the reciever so sound will come out and what setting on front do i use, please help, thanks
  • 4 Answers
Try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Posted on Mar 17, 2009
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
I have a Kenwood vr-405 and for the most part it works. I have been noticing that one front speaker is quite a bit louder than any other speaker. I have tried to adjust it many times and it seems like...
Maybe you should first isolate the problem to the receiver or the speaker by swapping the front speakers with each other to see if the loudness stays with the channel of the speaker.
Or, the acoustics of the room just make that speaker seem louder at the listening position. Try taming it with the adjustments provided in the receiver.
The manual can be found at http://www.retrevo.com/s/Kenwood-VR-405-Receivers-review-manual/id/480ag202/t/1-2/
Aug 18, 2010 | Kenwood VR-405 Receiver
How to hook up a kenwood audio-video surround receiver vr-405 to a 46" Bravia tv?
hello all you need is a good pair of RCA cables.
Use the audio output on the TV
run it to the VIDEO 1 input on the receiver
as for your DVD player vcr etc you can either run them directly to the tv as it will output whatever sound is playing to the receiver.
or
use the receiver as a video switcher and connect your components directly to it.
remember your receiver will need to be set to the input you use. ie: video 1 / dvd etc..
Hope that helps
Jan 10, 2010 | Kenwood VR-405 Receiver
How do i get dolby digital to work on my kenwood vr0405 reciever?
Make sure your source is playing something that has been recorded in dolby digital, not all dvd's and tv boxes transmit dolby digital. what is your source?
Dan
Dec 27, 2009 | Kenwood VR-405 Receiver
Reear speakers not putting out sound
If the TV sound source is through stereo RCA cables you'll only get rear sound if you choose one of the DSP modes. A digital source might work as expected, IF you have things correctly set up for multi-channel.
Dec 26, 2009 | Kenwood VR-405 Receiver
Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
Mar 23, 2009 | Kenwood VR-405 Receiver
Very low sound on TV and DVD no tuner
audio out from your tv to your reciever gives low output? how do you have everything hooked up i have vcr to tv dvd to vcr audio to my reciever and vcr tv thru piggy back plugs therefore i can only have tv audio or reciever or both
Dec 03, 2008 | Denon AVR-2800 Receiver
Hook up,s
Hi-I used to be a DirecTV installer. Depending on the type of reciever you have, there are yellow/red/white or red/green/blue outputs on the back. You will need to run the dvd/vcr through these and then change the tv to video 1/ video2, or AVI, CV1, CV2, Front (or whatever acronymn your tv has) when you want to switch between the componet and the reciever.... you should only need to change the tv channel to be able to use the dvd player. I've found that vcr's usually need to be on channel 3 and if DirecTV is using ch 3, you may have to slide the button on the back of the reciever to ch 4 instead.
Jul 24, 2008 | Televison & Video
Kenwood VR-405
more info would be nice. If you're using optical, make sure its securely in both the tv and your vr-405 receiver. I have owned the vr-405 since 2000 and i just purchased a sony 32xbr6. HDMI into the TV, optical out to the receiver, it sounds amazing!
Dec 01, 2007 | Kenwood VR-405 Receiver
Kenwood VR-405 Receiver Logo
247 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
