Question about RTO W/ Overflow Chrome 1 5/8" Vessel Sink Pop-up Drain
Pegasus Push Button Vessel Sink Drain with overflow
I purchased two vitrous china vessel sinks with overflow hole. I then purchased two each Pegasus Push button drains with overflow
( 241 405 ). Because of the overflow feature, and the accompanying sketch and instructions, I am at a loss to figure out how the manufacturer expects to seal for leaks.I am planning on placing the vessel sink( which has a mounting flange about 6" in diameter ) on top of my new granite countertop. The sketch shows the draing being installed with an "O' ring under the top mounting flange . Then the drain is placed into the hole and an "O" ring and flange nut are tightened on the BOTTOM side of the granite countertop. This leaves the MATING surface of the sink and the countertop unsealed.Since the overflow side hole in the drain fitting allows water too be present between the outside surface of the drain fitting and the inner surface of the holes in the sink and the countertop to be only restricted by the lower "O" ring and gland nut, which I believe will be an area to create a leak. THE MANUFACTURER DOES NOT ADDRESS THIS! Am I missing something? Should the countertop installer have drilled a hole in the countertop large enough to allow the drain to be pre-assembled to the sink and then dropped throught the countertop hole, which would leave only sealant under the sink mounting flange to secure the sink to the countertop?
I would appreciate "insider" info on how to properly install these sinks.
  • 2 more comments
  • jokawa Feb 21, 2009
    What about the mating surface between the countertop and the sink? Should I put plumbers puutey there as well since the water will make contact with that area?
  • John Robinson Apr 01, 2009
    Same problem. Vessel to chrome mounting ring with rubber gasket between. Then directions have you place the polished chrome side down on the granite top, no gasket or sealer of any kind. Makes no sense. The overflow drain basically uses the space between the drain pipe and the hole in the granite as a water bowl for the overflow to spill into until it finds its way into the 2 holes. All the water never gets out of here (holes are too high) and the water then seeps out onto the counter under the vessel.
    Underneath the counter is even worse leaking between the rubber gasket and the bottom of the granite.
    It seems that some other gaskets should have been thought of for this installation.
    Does anybody have a fix??
  • Anonymous Apr 22, 2009
    My sink leaks from these oval holes in the side of the drain. Bad design.
  • John Robinson May 11, 2010
    I can not get putty everywhere but will try some and return.
    President:
  • 2,976 Answers
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Posted on Feb 21, 2009
  • David Shaub Feb 24, 2009
    Anywhere you have a sink to counter or drain to sink or tub, you should use plumbers putty. Don't try using caulk, it will fail. The plumbers putty will seal and stay sealed for 30-40 years. After that, it won't fail, the sink will probably be replaced.
Where can I get a blow up diagram of a Model JY5000261 kitchen faucet?
try WWW.HDSUPPLYSOLUTIONS.com their faucet repair parts section has many expanded part diagrams
Jun 12, 2014 | Pegasus Technologies Pegasus Clear Round...
I installed the sink drain with overflow and water is leaking from behind the sink and under the countertop. What did I do wrong.
a vessel I dont beleive has a overflow. you need a differant waste for that unless theres something your not telling me
Sep 03, 2011 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
I AM LOOKING FOR A THE RING AROUNG THE DRAIN HOLE FOR A PEGASUS BIMINI VANITY
Standard rings can be bought at your local hardware store. It will be easiest to replace the whole stopper assembly instead of trying to match the ring to an existing stopper. You will need some plumbers putty and a pipe wrench.
Feb 11, 2010 | Pegasus Technologies Pegasus Pegasus...
Some water sits in the bottom and does not drain completely. Don't know if the drain inside the sink was not properly installed or if the sink is designed that way.
this is not supposed to happen, either drain not installed properly or drain is clogged. suggest trying drain cleaner first if sink has been in for a period of time. if sink is recently installed call whoever installed and have them fix the drain
Oct 30, 2009 | Pegasus Technologies Pegasus Clear Round...
Vessel sink's drain is leaking
a waste with a over flow does not work well with a vessel sink because the sink is to thin
Jun 16, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
How do I contact Pegasus to obtain missing parts?
Pegasus is Home Depot own brand of bath room fixture. The contact number should be on the installation instruction or the warranty sheet.
you shold contact Home Depot if you cna't find the contact number.
Mar 28, 2009 | Pegasus Technologies Pegasus Pegasus...
RTO W/ Overflow Chrome 1 5/8" Vessel Sink Pop-up Drain Logo
6,083 people viewed this question
Top RTO Plumbing Experts
Paul Carew
Tom Chichester
Are you a RTO Plumbing Expert? Answer questions, earn points and help others
