Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Posted on Feb 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AFTER HOOKING UP THE ICE MAKER AND WATER LINE WHAT DO WE DO TO FLUSH THE LINE .how long do we wait,what is the procedure.
Anonymous
Level 3:
Genius:
  • Master 1,122 Answers
  • Posted on Mar 02, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1122
Questions
5
Helped
316539
Points
2771
IT TAKES ABOUT 24 HOURS TO GET YOUR FIRST LOAD OF ICE,THROW THAT AWAY AND YOUR READY-MIKE
2answers
We have a igloo counter top ice maker the ice has a metal taste to it.
Taste is generally associated with the water entering the freezer chamber. You should have a FILTER in line with the ice maker to avoid the problem.
Why is my lg refrigerator making black ice
dirty water, filter? flush waterlines out before hooking it up to refrigerator.
After installing a stainlesssteel braided hose for my ice maker ( replaed a copper line) the ice cubes taste metalic. Is this normal?
No Its not normal, first of all did you flush the entire line and replace the filter at the same time? All of this is a factor. A stainless steel line is nothing more than a rubber hose wrapped in a steel mess, it very easy to move around and install. I think allow time for the water to settle and flush out the entire water system with a filter change should fix this issue.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
1helpful
Ice maker not working
The activity with the water supply could have loosened some sediment in the line stopping up the little wire screen filter going into the water inlet valve. I would disconnect it and inspect the screen and flush the water line out before re connecting. Assuming you have water at the water dispenser Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Water lines i think are ok but cant get water or make ice
Check the following:
See if the fridge has a water filter...it could be plugged and need replacement...check your manual for the location and replacement procedures
Check the inlet water line to the ice maker...it could be frozen...a hair dryer can be used to thaw it out and get the ice make to work again...be careful and don't overheat the ice maker inlet water line.
Make sure the water line is ok and not obstructed or kinked
Check the ice maker water valve to be sure it opens and isn't clogged
Cycle the arm on the ice maker and wait to see if it will make ice again
4helpful
Ice maker
My wife installed a new filter and didn't purge (AKA flush) it enough. As a result, my ice maker quit. Since there was air in the line, the water feed into the ice maker froze. You should check your water feed. In your freezer, look to the top right part of your ice maker. You will see a short (2 inches or so) black tube that feeds water into a piece a plastic on your ice maker that looks like a small cup. Squeeze the tube to see if frozen. If it is, there is probably also a frozen pool of water in the 'ice maker' cup. You can use a hairdryer but be very careful as you can melt the plastic. My service guy took out the ice maker and ran it under hot water. He used a small screw driver to get the ice out of the black hose. Removing the ice maker looked pretty easy. You can remove the ice maker door (it justs snaps out). the ice maker also just slides out. If you are not comfortable removing the wire connection, there's enough plat in the wire to allow you access to the frozen cup of water. You could pour hot water over the ice maker while it remains connected. When done, cut power to the entire frig for about a minute. This will reset the ice maker. Note that you may have a wait a few minutes to actually hear the ice maker fill with water since it has a timer mechanism.
Whirlpool refrigerator waterline is clogged
go to the back of the ref, trace the incoming water line, it should go to a two pc solenoid valve. if you press water at the front, one of the solenoid should click. the one that didn't click is the one for the ice maker. see if you can detach the water line that comes out of that solenoid. that line goes to the ice maker. you can flush it with water to clean it. be aware that a lot of water would be overflowing inside the ice maker . i hope i was able to solve your problem..
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
