Question about Kenwood 1090VR Receiver
Kenwood 1090vr; amp shuts off
Kenwood 1090vr; I'll press power and the phono selection will blink 4 times and then the amp shuts down. I've removed all wiring to check and see if another compenent was the cause, but no luck. Any Suggestions? Thanks!
  • 15,935 Answers
The source switching relay has failed.
It will need professional repair.
Approximately $60
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 21, 2009
  • blueextc3221
    blueextc3221 Feb 21, 2009
    CLICK HERE for a link to your owner's manual.
    You can try a Manual reset of your unit ..
    Unplug your unit from the wall
    Press and HOLD power button - while plugging back in.
    Brigadier General:
  • 3,614 Answers
a possible problem on the power board area. check and inspect for any burnt or failing IC.
  • micromaster
    micromaster Feb 21, 2009
    better to look for any service engineer near the area.
    thanks for using fixya.
Although my turntable seems to be fine there is hardly any sound coming through my amp/speakers from it. I'm using a different power lead for it since I've lost my original but it fits fine an
your needle has worn down, or the RCA leads(red & white) arn't plugged in to the phono socket on the amp,or you haven't selected phono on the source select,or you have the tape monitor button switched on.
Jul 07, 2012 | Technics SL-BD22 Turntable
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
I have had a Kenwood VR-407 reciever for almost 9 years now but it has just started cutting off. The small power/standby light above the power button goes off when I power it up but then it shortly...
If you've already disconnected the speakers then I suspect the fault is internal on the amplifier and the unit is shutting down to protect iteself.
The fault with most amplfiers can normally be traced to blown or leading capacitors (bulge on the top or liquid around base) which can be replaced for little cost if you've got the technical ability and equipment to desolder and resolder components on a PCB.
First thing to do would be to remove the cover and check the capacitors as detailed above.
Jul 23, 2011 | Kenwood VR-407 Receiver
How do you set the clock on the Kenwood DPX302
In the standby mode:
1. Push the Control knob towards up or down, select "CLK ADJ"
2. Press the Control knob for about 1 second, the clock display blinks
3. Push the Control knob towards up or down to set the hour
Push the Control knob towards right or left to adjust the minutes,
4. Press the Menu button
Mar 01, 2011 | Kenwood DPX302 CD Player
I have hooked up all the wires in the appropriate color-coded order and my stereo has no reception. It has power but no reception. The antenna is hooked up also. It is a Kenwood KDC 119 and the vehicle...
Selecting the station. 1 Select tuner source Press the [SRC] button. Select the "TUnE" display. 2 Select the band Press the [FM] or [AM] button. Each time the [FM] button is pressed it switches between the FM1, FM2, and FM3 bands. 3 Tune up or down band Press the [4] or [¢] button. During reception of stereo stations the "ST" indicator is ON. 1 Select the band Press the [FM] or [AM] button. 2 Select the frequency to put in the memory Press the [4] or [¢] button. 3 Put the frequency in the memory Press the [#1] - [#6] button for at least 2 seconds. The preset number display blinks 1 time. On each band, 1 station can be put in the memory on each [#1] - [#6] button.
Nov 03, 2010 | Car Audio & Video
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Kenwood Tuner Works Through amp, CD & Ipod dont turn on amp
You have the amplifier remote and power antenna remote installed backward. Switch them. The radio drops power to the power antenna when you choose a source other than TUNER... thereby shutting the signal down to the amplifier's remote turn on lead.
See the bottom comment of the tip AT THIS LINK. under NOTES:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 15, 2009 | Kenwood KDC-MP238 CD Player
Kenwood:1090VR Cracking sound from front speakers
There are poor solder connections somewhere on the board. Usually these are at the voltage regulators where there can be some heat. Look for 3-legged transistors attached to small metal heatsinks, If you can solder, resolder the pins on those parts. Also look for any connections that appear to be grasiny or have rings and resolder them too.
Keep us posted.
Dan
Feb 06, 2009 | Kenwood 1090VR Receiver
Kenwood 1090VR loses sound after a few minutes
First thing to do is to check if this KENWOOD have an input at the back then you try another player i mean dvd player or anything that you can drive or cassette then hear if the same happened again there is something overheating and i pinpiont directly the Power IC is leaking.subject to change.See the number of the IC then buy the same number and change.
Jan 05, 2008 | Kenwood 1090VR Receiver
106 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
