Question about Kenmore Washing Machines
Motor works, gear-like raspy noise no action
I,m not sure how to get inside to summerize the problem, looking for schematic. the machine is approx. 10 yrs. old
  • 15,935 Answers
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Was working then made a raspi noise now nothing works
Sounds like you might have a problem with metal in the oven. Look inside the oven including the "ceiling" and see if the finish has worn off, leaving bare metal. If so, wash that area thoroughly, dry, sand lightly. Then apply some appliance paint that comes in tiny bottles and costs about $4.
Nov 16, 2013 | Amana ACM1580AS Microwave Oven
Blows breaker and groweling noise
It sounds like the motor is bogging down due to bad bearings or something is making the shaft too hard to spin. Make sure all the spindles are free. If its happening under load, make sure the lathe gets up to speed before trying to make any cuts.
Oct 18, 2012 | Ammco Combination Disc/Drum Brake Lathe
Toro Personal Pace Mower won't start w/ electric starter
There are a couple of things you can check;
First, check to make sure the bendix is engaging. It is the gear that meshes with the fly wheel.
If it is, then try and see how fast the motor is spinning. Don't look at the blade though. It could be a faulty starter motor.
Make sure to also check the battery voltage with a volt meter. It should read at 12.0 or higher.
Sep 07, 2009 | Toro Lawn Mower With Toro Power Tools
I have Xerox XD100. Machine is very noise. The noise is coming from back of machine. Sand like motor is turning but something is stock (can not moveThis motor look like suppose to move)
There is a small helix gear attached to the shaft of the main drive motor. It cracks or shreads on the inside. You will have to replace the main motor. Not real expensive or difficult to replace.
May 28, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
When you move the temp. control from hot to cold there is a nocking or clicking noise. doesn't sound any thing like an air lock in the heater core. sounds more like its in the heater duct
there is a vacuum operated flap that moves in there.check and see if something is stuck,or a foreign object from the dash maybe fell inside through the defroster vents.
May 15, 2009 | 2000 Ford Windstar
Loud grinding noise when paper is feeding through machine
Mine was indeed a gear problem. Took off the top cover and poked around. Found two areas that may have caused the grinding.
1. The lower roller shaft had slid to the left out of it's groove. By removing the handset cradle (3 release tabs are accessed underneath the toner hatch.) I could loosen the "gear box" (a black contraption with all the gears inside) and then snug the bottom roller into proper position.
2. I removed the "gear box" to look around. Don't know if I dislodged one of the gears while doing so, but noticed one was dislodged ;-)
This required opening up the gear box by removing 2 screws and lifting off the motor. Then i could get at a gear that had come loose from a claw sort of piece. Note: the teeth of the loose gear needed to be on the motor side when sliding it back into the claw thingy. It seems to use a metal clip for friction control and perhaps proper spacing.
I noticed "some" wearing of gears, but doubt this is an issue. This machine has been used VERY hard for years and now, just by re-aligning things, it works once again.
My googling barely found any mention of troubleshooting this machine, so I shudder to think what finding parts would be like.
Jan 19, 2009 | Brother IntelliFAX 2800 Laser Fax
The agitater has stopped working
Belt needing to be replaced is obvious.
As for a schematic of the motor, I think what you are really needing is a wiring diagram and schematic of the complete washing machine. Most often, there is a paper one glued to the inside of the removable panel on the back of the washing machine. Either there, or inside the control head on the top of the washing machine.
Please include the specific model number in any replies.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Blinking "L" message
If it has that high pitchied noise it is the main drive motor gear has cracked. Unplug the machine and remove the back cover. Looking from the back the motor is just left of center and about mid way down the machine, A couple of connectors and 4 phillips screws hold it in place. Remove it and there is a small helix type gear affixed to the shaft. It may not even look crackes but you will be able make it slip on the shaft, It isnt all that expensive to relace.
https://www.partsdrop.com/store/
Contact this business, call and ask for Britt, he will help you with what you need. Good people to deal with. NO I DO NOT work there, just do business with them and they are first class.
Jul 09, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Washing Machines Logo
26 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
