Question about True GDM-41 Refrigerator
The doors stick when they close. how do I lube the pullies
  • 4 Answers
Your door rollers are probably worn off.
To access these carefully lift the door off the rail, pull it out bottom first then unhook the string attached to the counter weight from the top part of the door .Tip the door upside down and you should be able to see 2 or 3 rollers spaced on the bottom track (or what is left of it
Posted on May 13, 2009
Door locked and will not unlock and cant shut door
sounds like the door latch mechanism is stuck in the closed position. if you pull on the door handle and use something like a screw driver and pull the latch claws open the door should work. the latch is the part that closes around the door striker plate bolt to keep the door closed. lube the latch to help keep it from sticking again.
Sep 04, 2014 | Honda Accord Cars & Trucks
Front doors wont unlock
is it below freezing outside.. doors frozen closed?? what..use regular room temp water from a gallon jug and pour it over the door seal area all the way around the door.. once opened.. take a bar of soap or vaseline and coat the entire door seal to help keep the door from sticking in the future. do this every coulpe of weeks and spray the door mechanism with wd40 or spray lube in a can so it wont stick either..
Dec 15, 2013 | 1996 Chevrolet Suburban
My door warning light stays on even after checking that all doors are closed
An easy fix that sometimes helps, is get a can of WD40 or any spray lube, go to each door one at a time and spray the lube in the latch close 2 or 3 times and see if light goes off. Generally the drivers door is the problem the switch just sticks with dirt
Apr 26, 2011 | Ford Futura Cars & Trucks
My drivers side door doesn't close all the way because the lock in the door only latches about half way..It will stay closed going down the road,, BUT it's not latched or closed tight.
sounds like the latch is broken or the latch catch is out of alignment. you can try and spray some teflon or silicone based lube on the latch and see if it is just sticking -- some lube goes along way on moving parts. also make sure the door is lining up proper and not hitting anywhere on the frame.
but I would try the lube first,, and then look into possibly replacing the latch.
c...
Feb 02, 2011 | 1995 Plymouth Voyager
Recently, the inside light on my 2003 Chevy cavalier began fading on while I'm driving or when I stop at a light. Sometimes it fades off when I start moving again built it also stays on after I park, shut...
Sounds like your light switch is sticking ,you'll have to find it and lubricate it with penetrating lube.The switch may be a plunger switch that moves when the door is closed ,but I think it's part of the latch.Spray the switch and open and close the door to work in the lube.
Dec 11, 2009 | 2003 Chevrolet Cavalier
Loud squeling
no lube points
your idler pully is probaly sticking and should be replaced before it wears your belt and that snaps
Oct 07, 2009 | Dryers
Freezer door light switch sticks, have to pull on switch nob.
sand it with 600 grit sand paper. and spray some lube W-D-40 on it.
Jul 25, 2009 | Sub-Zero 690 Side by Side Refrigerator
Doors won't close
Stick a screw driver in where it would normally wrap around striker at door, pull handle and it should flip open there to allow closing. When working properly, it should snap back on its own when handle pulled so I'd give it lots of lube to see if it will start working properly.
Jun 01, 2009 | 1995 Oldsmobile Cutlass Supreme
Interior dome light/exterior cab light stays on -won't shut off
Lube your door latches. One of the door ajar switches are sticking . Use wd40 or some othe spray lube . Spray into the latch and open and close doors several time.
Jan 25, 2009 | 2000 Ford F250 Super Duty Crew Cabs
2003 Explorer door ajar light stay on when all doors are closed
I had this problem on my 2003 explorer and took WD40 and gave the lock mechanism a good dose where it meets the clasp on the door jam. Then open and close the doors a couple of times to get them working. They get gummed up and sometimes have a tendency to stick.
Dec 29, 2008 | 2003 Ford Explorer
True GDM-41 Refrigerator Logo
104 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
