Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Vacuum is losing suction
It seems like my Dyson vacuum is losing suction but the hose isn't clogged and the filter is clean. I have to go over areas several times in order to **** things up. Can you help with this?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 83 Answers
There are a couple of things you can do and it depends on whether you don't have suction from both the wand and the bottom of the
machine or just from one side:
1) First check the suction of the machine to ensure that the motor is still good - remove the canister and look for the two
openings/holes on the spine/frame of the machine - put your hand in front of the hole on the LEFT (higher than the hole on the right)
- if there is suction, continue the troubleshoot instructions, if there is no suction your motor may be damaged - call the Dyson
Helpline, they'll set you up with a repair with the closest authorized dealer in your area.
2) Check for blockages from the bottom of the machine. Remove the:
(i) U-Bend (stand behind the machine and look next to the right-hand-side wheel, it's attached with a rectangular clip next to the
long gray hose - push the clip and pull the U-Bend off, make sure its clear - if there's a blockage remove it and continue with the
blockage check to ensure that the entire machine is clear)
(ii) AI Valve (stand behind the machine and look above the right-hand side wheel, it's attached with two buttons on either side of the
AI Pipe/Valve - push the two buttons and pull the pipe up and off and make sure there is clear - if there's a blockage remove it and
continue with the blockage check to ensure that the entire machine is clear)
(iii) Refit the internal hose on the bottom of the machine between the wheels and make sure it isn't torn and has no holes in it and
that there is nothing clogged inside it - to refit the hose: Pull it off where it sits next to the wheel first - make sure that the
gray piece of rubber is still on the hose (if it isn't, pull the gray piece of rubber off the hole and reconnect it to the hose by
twisting it back on) - next, twist the hose off where it connects to the brushbar - inspect the hose and make sure you don't have any
holes in it - put it back on by twisting it onto the side of the brushbar first - then line the gray piece of plastic end up with the
hole next to the wheel and push and twist it back over the hole. Bring the machine back upright and test it
3) Check for blockages in the wand. Remove the:
(ii) Wand - take the wand off the back of the machine - put one hand on the wand handle and one hand on the gray hose - pull the
handle and push the gray hose down, you'll see a metal rod being exposed, push the hose until it clicks into place - press the
half-moon shape button with a picture of a lock on it (found on the solid gray plastic end of the flexible hose) and separate the wand
competely - point the wand into the air or at a source of light (please don't point it at the sun) and look through the metal rod part
- the handle is bent but you should still see some light coming through the other end - if you don't, there is a blockage in the wand
- use a long object like a stick or a metal hanger to remove the blockage
(iii) Hose - no need to remove it - just stretch it out and make sure that there are no dark spots in the hose (those would be
blockages) - you can also through the top of the hose - if you don't see the ground at the bottom there is a blockage in the hose
4) If no blockages are found on the machine at all:
(i) wash the filter in cold water and leave it out to dry for at least 24 hours
(ii) blow out the cyclone from the bottom (open the door on the bin door - you can now look into the cyclone) - blow it out with an
air compressor or a leaf blower
(iii) Wipe all the small holes off on the cyclone with a dryer sheet
When the filter is dry, test the suction again. If there still is no suction on the machine, call the Dyson Helpline, they'll set you
Posted on Jul 30, 2009
SOURCE: Suction
i can think of 2 things first do"s the clutch{ if it has one}work or is it in the off postion you can test this by lying the dyson on it"s side and turning it on but remember to push down on the bottom as if you was hoovering if the brush spins then its ok if it dosen" move then replace it second take the bucket off and remove the bin tune it upside down and see if it is blocked if so the best way to clean it is to sit it upside down and put a hose pipe in then just wait till the water runs clean hope this is some use to you
Posted on May 22, 2007
SOURCE: Dyson Animal clogged
Here is the best way to clean your dyson that I have found!
http://www.crazysquirrel.com/diy/dyson/cylinder-clean-page-1.jspx
Posted on Mar 02, 2008
SOURCE: Dyson DC07 hose has no suction
Just resolved the same problem...couldn't find a blockage anywhere, but pulled handle out of hose and extended hose as far as possible upward. Aha! There was blockage in the hose at the very bottom where the flexible hose meets the rigid part.. There is a lever which releases the entry to the bottom of the hose. A pencil, lots of coins, a crumpled receipt and general dirt were stuck. Easy to clean and now it works like new again.
Posted on Aug 09, 2009
  • 5 Answers
SOURCE: dyson 18 losing suction
Check the HEPA filter if it has one. This bit of foam gets clogged over time and significantly reduces the suction especially if you've been vacuuming a lot of very dusty areas i.e. dust from building work etc. Just wash the filter with lots of water and leave to dry before reinserting.
Posted on Aug 12, 2009
  • 8404 Answers
SOURCE: No suction - Infinity Shark Vacuum NV31C
You might try sucking the sose out with another vacum from the wrong way. You might be able to remove the hose and push a broom handle or stiff wire through. If you have compressed air available, you could try that, outside.
Im sure you have a clog and if you remove it, you will be back in business.
Thanks for your interest in FizYa.com
Posted on Dec 11, 2009
No suction from dyson dc24
Clean or replace filters if needed. Check for suction at wand, if not good could be a clog somewhere or clogged filters, or a leak in the suction somewhere. If good at hose but not at floor it could be a clog or malfunction in changeover valve area. Make sure brush roll is spinning good and brush roll not worn out or frayed.
Mar 14, 2017 | Dyson Vacuums
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson vacuum cleaner doesn't seem to have the same suction power it used to. I have cleaned out the canister and have taken apart the vacuum head (for cleaning carpets) and it doesn't seem to be...
Hello, this is Ava with Think Crucial.
Most of the time the reason why the vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this.
You can purchase a wide variety of high-quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 08, 2011 | Vacuums
Hi loss of suction on Dyson DC07 and I have changed the belt on the brushbar and cleaned all filters/removeable parts but still suction not very good, any other suggestions?
Check for a clog where the power nozzle connects to the hose. Clogs or leaks in the hose will both cause loss of suction/air flow. Another possibility is broken or worn out fan blades.
Nov 13, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Wand lost suction
cleaning all filter Assy and all Handle Assy and Hose Assy...
Nov 06, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Problems with Dyson DC14 Animal Bagless Vacuum very little suction coming from the hose. cleaned filter and suction has not improved. Please help. Thanks
Two possible solutions come to mind. First off, there is a clog in your hose. If you have another vacuum, try using the hose on that one to **** it out.
If that doesn't work, you may need to have the clutch replaced. Check your warranty. The clog wont be covered, but the clutch will be,
Oct 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a dyson dc 17 what is the best way to thourghly cleaning , so I can get better suction , also do you have a instruction manul to. I seem to have misplaced mine thanks
The first step towards improving the suction is to clean the circular HEPA filter. The filter also houses a circular sponge which should be rinsed and dried before putting it back. Check the HEPA filter to see if it needs replacement -- will look muddy! Another quick check is to remove the HEPA filter, run the vacuum cleaner momentarily in upright position to check if suction is restored at the hose end.
After doing this if suction is still poor or non existent, you should detach the transparent canister - a bit tricky since the release rod for the flap has to be aligned when you want to reassemble the unit.
Once the canister is removed, you should check and clean the center tube/shaft for any clogged dust (use a wire coat hanger if needed to pry out the dust). This tube gets clogged if the vacuum cleaner was used to pick up damp/wet spills etc.
Sep 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Dyson D17 won't work while upright.
check and make sure you have the gasket installed correctly that goes on the center of the cyclone and seals against the canister trap door. If this is backwards, you can lose a lot of suction and it will plug your permanent filter quickly.
Sep 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Low Suction When Using the hoses on the Dyson Animal
there is a washable filter either on the side of the motor or in the dust cup clean it out using water make sure it is dry before reinstalling also check for clogs there are several pices that are removeable the peice under the hose and vent clip? on the side remove and check for clogs
May 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
835 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
