Question about Canon PIXMA iP1500 InkJet Photo Printer
Reset canon iP 1600 waste ink counter
Need to reset canon iP 1600 waste ink counter
  • 447 Answers
This link should help you with your problem.
Posted on Feb 21, 2009
Canon Pixma Ip1700 will not print, because the Ink absorber is full.
Hi there
Please under-stand at some time you will need to clean out the waste inkpads that are inside your printer or it going to be a big mess of inks coming out.
Some times the IP tools will fix it Canon Pixma iP1200, iP1600, iP2200 Resetter
1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Tip
How to reset waste ink counter canon ip 1000 printer?
There are 4 simple steps to Reset waste ink tank counter CANON PIXMA iP 1000STEP 1:- Disconnect printer from AC power.
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power.
STEP 3:- Release the the POWER button.
STEP 4:- Press the POWER button again.
on Mar 10, 2010 | Office Equipment & Supplies
Computer wont reconize ink cartidge
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
2. Unzip downloaded file by etc
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Nov 02, 2009 | Canon PIXMA iP1600 Printer
My Canon PIXMA iP 1600 - Waste Ink Absorber Almost Full what do I do?
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Then download this tool unzip it and start it.Select the connected USB port number from USB PORT.Click LOCK RELEASE, and select the applicable model name in SET DESTINATION.In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Oct 14, 2009 | Canon PIXMA iP1600 Printer
My canon pixma ip 1600 waste ink absorber is full
hello sorry my friend who only speak English and in Spanish, you step solution for your printer ip1600 canon, you have to do is reset the counter of step tinta.te a link to the manual and program for this work. el programa :http://rapidshare.com/files/121528528/iP1600ServiceToolV129.by.karlpl.rar and the manual is here http://rapidshare.com/files/121529238/Manual.by.karlpl.rar
May 07, 2009 | Canon PIXMA iP1600 Printer
Canon Pixma iP 1600 will not print
Hi there
4.Close The Cover
Feb 22, 2009 | Canon PIXMA iP1600 Printer
How do I clean out my waste ink on my Canon IP 2200 printer
Hi. I researched on this and found that these steps have fixed the problems most of time. Also, it does the required procedure automatically.
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.
Feb 07, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Cannon printer pixma ip 1600 ink absorber full
Dear khalid,
To fix this problem you need to reset waste ink counter of the printer by using General Tools for Canon ip1200 series (General Tools for ip1300 & 1800 series also works on this printer)
Perform following step to reset waste ink counter:
  • Enter service mode:
-Plug in power cable while holding power button.
-Press RESUME button twice
  • Connect USB cable (you may also connect USB cable before entering service mode, no problem).
  • Run General Tool
  • Select USB port
  • Click waste ink counter: Main & Platen
  • Turn off the printer then turn on and run your printer as usual.
I think it will be more helpful with picture enclose. For I cannot insert image more than 150 kb here, I suggest you to visit Canon Inkjet Printer Forum. I have discussed this topic before.
Please rate me.
Regards,
Nov 26, 2008 | Canon PIXMA iP1600 Printer
Error message
Hi there
4.Close The Cover
Jun 30, 2008 | Canon PIXMA iP1600 Printer
Waste ink absorber on canon iP 1600
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
Aug 13, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
495 people viewed this question
old marine
old marine
