SOURCE: I have an AR-M160 and have an L error. How can I
this L6 ERROR IS USUALLY TO DO WITH THE POLYGON MOTOR IS IT L6-10
SOURCE: sharp ar-m160 h2 error code
chack the fusing units the thermistor is open
&thermistor abnormality chack the harness and the
connector between the thermistor and the pwb
use simulation mode(# interaput c interaput )
preas the 14 toclear the self diagnostc dis play
SOURCE: i need drivers of my sharp AR-M160 for windows 7
Your printer doesn't support Windows 7.But it support Windows Vista.
Here is the driver download page from www.sharpusa.com
http://www.sharpusa.com/CustomerSupport/ProductDownload.aspx
Fill the form as below
Select a Product Category : MFPs & Printers
Enter Product Model : Models not listed
Enter Product Model : AR-M160
Select a Download Type : Driver
Driver Platform : Microsoft
Operating System : windows Vista
And click "search"
Your printer drivers will be listed below.Click on the driver name (Red colour text),your driver will be downloaded now.
Note : Drivers which are meant for Windows Vista usually Work with Windows 7 too.you can give it a try.
SOURCE: Sharp AR-M160 Maintenance light and developer
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
enter the simulation mode:
"#" key Interrupt key "C" key Interrupt key
press 14 and START key
the copier should restart in most cases.
if not:
There is a problem in the fusing area, bad Thermistor, defective ThermalFuse, defective heating lamp.
