Question about Acer TravelMate 2300 Notebook
Acer laptop travemate wont even make any noise or boot up... why?
I have an acer laptop model CL51 ... the LCD lights for the battery and processor just flashes once and stand on but no booting up. no spining of the fan too.. whats wrong with my motherboard.. acn someone please giude me to happiness..
Puppy X
  • puppyx1 Feb 28, 2009
    i have tried what you told me Miller but none of it worked.. i therefore thinks of the motherboard any solution to that or i need to buy a new note book..? but i loved this notbook soo much..
    thanks for your thought hoping to hear another info again from you.
    New Friend:
  • 15 Answers
My initial thought would be that your battery will no longer hold a charge or that your power supply has gone bad. Try taking the battery out and booting the computer with JUST the charger. Any change? How about booting from the battery alone? Have you had any spills on or near it in the last 6 months? If it turns out to be a battery, you can buy them online for around $70. There seems to be an abundance of parts for this model acer. It definitely sounds power related though. If its not the battery or the power supply, my last guess would be the motherboard. Good luck and let me know if things change as your are testing it.
Posted on Feb 27, 2009
  • kirkmiller Mar 01, 2009
    I found a motherboard exchange online for $364 but you'll have to take your laptop apart and remove the motherboard. Then ship the damaged motherboard to the exchange place and let them ship you a new one. The question is... is $364 worth saving your laptop? There are several new laptops not too far from this price-wise. Depending on how much you "LOVE" your CL51, you may want to salvage it but in todays electronics world everything is fairly disposable. (unfortunately). If you choose to replace the motherboard, as a matter of isolating the problem, I would remove all but the minimal ram and try and boot it (althought I seriously doubt that is the problem.) If you have a spare hard drive laying around you can try a swap but again I doubt thats the problem. What is DOES sound like to me is the power control section of the motherboard. That particular laptop looks like it is a little older, so one option might be to save the $364, sell it on ebay as-is, and put your money toward a new laptop. Once you buy one, you can get a very reliable warranty from squaretrade.com for a few dollars. Then, next time something happens you will be covered. Either way, you can replace the motherboard or the whole laptop.
    I will be happy to continue to answer any questions you may have.... Just post here.
    The motherboard exhange site is:
    http://www.notebooksolutions.ca/zc/index...
Acer Aspire 7720-6155 wont boot
put cd in dvd writer then open the laptop and press f8 and after that if lap asked for esc/ or for enter press esc then it will work .
Sep 12, 2013 | Acer ASPIRE 7720-6155 LAPTOP LCD SCREEN...
My laptop wont turn on
I think your battery or your whole motherboard is fried. Does it make any noises? Do the fans start to run? Try unplugging your battery and only keeping your charger in.
Jun 02, 2013 | Acer TravelMate C300 14.1 XGA LCD Display...
Acer Travelmate 3270 won't start?
Could be corrupt cmos, bad hard drive, bad memory, bad peripheral.
Remove hard drive and perform diagnostics on it to make sure it is good and not the source of issue.
Then check to see if machine is posting - if not, then you are in deep doo doo because without a posting procedure you cannot repair your OS, install a new one, nada.
A new mo bo will set you back 100 bucks on ebay: installation of mo bo on laptop is one Royal,, Royal PIA.
Sep 18, 2017 | Acer Computers & Internet
I cannot start my laptop,its say no bootable cd in atapi cd-rom and ntldr is missing-acer travelmate cl51
Either the boot record is corrupted or the drive is bad. You will need to reinstall the OS with your OS cd or restore your system to factory setting.
Feb 07, 2012 | Compal Custom CL51 Notebook
Laptop wont even boot up
Do you have it on a power strip? if so try resitting it,if the battery is at full charge then you have an internal problem in the laptop itself.Bad power board,etc.Hope this helps.
Jul 25, 2010 | Acer Aspire One PC Notebook
Travemate C110. I replaced the hinge which was broken. To do this I had to disconnect the screen. I reconnected but I don't have any light on the screen. I can see the faint outline of the Windows...
Either the inverter board is dead (cheap to replace) or the backlight built in to the lcd is dead. The inverter board is inside the plastic bezel (frame) of the lcd panel. It is located at the bottom centre. Take the display apart and disconnect and reconnect the 2 inverter board connectors. It's the only circuit board inside the lcd panel, so you can't miss it. If this doesn't work, maybe try a new inverter board from acer (if still in stock) or connect the laptop to an external monitor and use it as a stationary pc.
Regards,
Joe
May 18, 2010 | Acer TravelMate 2300 Notebook
LAPTOP WON'T EVEN BOOT. EVERYTIME I PUSH THE POWER BUTTON, THE GREEN LIGHT FLASHES AND IT DOESN'T BOOT UP
processor coolant needs to be replaced. find a way of reaching the processor, unscrew it and on the mirror or glass like part on the processor apply heat sink compound. and u back on the road. denis muwonge Uganda Africa
Mar 10, 2010 | Acer Aspire 4520-5582 Notebook
Hi i have an elonex cl51-15 laptop when i try to boot it it just keeps restarting and if i try to get into bios it wont let me any ideas??
try takeing the battery out and power lead and holding the power button pressed for about a minute ,plug ur battery back in and try
Feb 17, 2010 | ASI CL51-15 Notebook
My laptop Acer TravelMate CL51-15 doen't start up. the message is ''no boot divice found'' and i can't open my bios for configuration
first of all, you must find a way to get in the BIOS. You can google search ACER TRAVELMATE CL51-15 BIOS updater. ensure that the laptop is connected to the charger befre you do any BIOS update. then you should be able to detect the hard drive and install you desired OS.
Jan 25, 2010 | Acer Computers & Internet
Computers & Internet Logo
169 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
