Question about Necchi 3537 Mechanical Sewing Machine
Necchi Lydia type 544
Estimado senor Lopez, vivo en San Jose Costa Rica, y me madre me regalo la maquina de coser, ahora no enciende le quite la tapa en la base y me encontre con los cables electricos carcomidos por la humedad, ser posible que usted me guie para pder cambiarlos o tendra un manual para poder cambiar y conectarlos correctamente, ya que la maquina esta como nueva si no fuera por este prblema estaria usandola, gracias por su ayuda, mayra g. de laay
5 Suggested Answers
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Posted on May 06, 2009
  • 1116 Answers
SOURCE: How do I thread my necchi Lydia type 544 sewing machine
Threading guide - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_542_544_threading_Diagram.htm
Make sure the presser foot is up when threading any sewing machine.
Posted on Mar 06, 2010
pegsteve
SOURCE: I have a necchi lydia 544 sewing machine I am
universal walking foot on overstock.com , works great oin 99% of machines.
Posted on Sep 24, 2010
SOURCE: I am trying to find a motor for a Necchi Lydia 3
try sewingpartsonline.com or sewforless.com
Posted on Dec 01, 2010
SOURCE: need manual for necchi lydia 544 sewing machine
Hi,I have a manual for a necchi lydia 544 sewing machine.I can sell it to you for £7.50 plus £1 postage,email me Shirleyvictoria@yahoo.com.sg
Posted on Feb 24, 2011
No puedo enhebrar mi maquina de cose Janome
Muchas maquinas de coser si enhebrar de las misma manera.
Si ves el link, encontraras un manual por el maquina Janome 3128. En el manual hay dibujos de como enhebrar una maquina de coser. Espero que este ti ayuda.
http://www.janome.com/documents/File/ManualFile/3128.pdf
Sep 12, 2010 | Janome Harmony 2041
Preciso urgentemente de peças de reposição para a máquina de costura Toyota overlock diferencial SL 3404-D. podem ajudar?
Olha
Yo compre las piezas que faltaba a mi maquina Toyota 9090 en este sitio: http://www.aisin.fr/index3.php?language=en
Lo tiene piezas para la maquina SL3403 que creo que sera muito similar a tua maquina.
Yo vivo en Espanha y tuve las piezas en 4 dias desde Francia. La pieza que mi faltaba costo 19 euros y mandarlo costaba 16 euros!
Perdona no se escribir muito bem en Portugese, pero lo intento. Saludos y boa sorte
Aug 19, 2010 | Toyota TL-432DE Mechanical Sewing Machine
1. se enreda el hilo abajo y se rompe el hilo de arriba. 2. muy baja tensión del hilo de abajo. está en el límite de ajuste. Ajusté la bobina y mejoró pero sigue con el problema...
Hola! Espero que puedo ayudarle con su problema--pero, como hace mucho tiempo que no escribo en espanol, por favor, tenga paciencia conmigo.
Muchas veces ese problema de enredar el hilo del abajo resulta de la presencia de pequenos pedacitos de hilo en esa zona. Use un pequeno cepillo para saquar toditos.
Generalmente, no hay que adjustar la tension de las canillas (bobina?). Adjuste al punto que hay un poco de tension cuando jale un poco al hilo.
Casi siempre adjustando la tension de arriba solucionara todo.
Use hilos de diferente colors en la canilla (bobina) y arriba. Tambien, es major usar un aguja nueva. Usando un pedacito de su tela normal, empieza a coser. Cosa unos centimetros, y pare para cequear. Siempre adjuste la tension con la pie prensatelas abajo.
Si se ve el hilo de abajo (el del bobina) en la parte superior de la tela, el hilo superior esta demasiado tenso. Gire el equilibador de tension para disminui el numero.
Si el hilo superior esta demasiado flojo, se ve el hilo del bobina en el lado inferior de la tela. En ese caso, hay que amentar el numero.
En todo caso, hay que hacer las correciones lentamente,
Sequn mi guia, se rompe el hilo de la aguja:
1. No esta enhebrado correctamente 2. La tension del hilo de aguja es excesiva. 3. La aguja esta despuntada o doblada 4. La aguja no esta bien colocada. 5. Los hilos de la aguja y del bobino no estan bien colocados debajo del prensatelas al empezar a coser 6. La tela no se ha extraido hacia atras al terminar la costura 7. El hilo es demasiado grueso o fino para la aguja.
Ojala que eso le ayude y que mi espanol no esta demasiado feo.
Robbie
Feb 22, 2010 | Kenmore Sewing Machines
I NEED A MANUAL FOR A HUSQVARNA SEWING MACHINE MODEL 1070
Try calling Husqvarna Viking at: 1-800-474-6437, they can get you a photo copy of the original manual
Oct 16, 2009 | Husqvarna Sewing Machines
SE ME EXTRAVÍO LA DOCUMENTACION DE LA MAQUINA
Hay sitios on line donde se puede comprar documentacion para maquinas de coser. Trata primero Janome (www.janome.com). Otro sitio que tiene mucha informacion es http://www.sewingmanuals.com/.
Creo que New Home manufactura la maquinas Janome, asi que busca bajo los dos nombres.
Buena suerte!
Oct 05, 2009 | Janome 2049LX Mechanical Sewing Machine
Rompe el hilo
Saludos
Comunicate con la compa?ia de Euro Pro ellos pueden ayudarte, ahora bien debes de revisar las agujas, mi maquina hacia lo mismo que la tuya y simplemente era una cambio de agujas, tambien puedes revisar las cuchillas y la puntada o tension que este muy apretada, si despues de revisar todo esto no se resuelve pues comunicate con la compa?ia 1 800 361 4639, ellos te ayudaran, estas maquinas son buenisimas y es una lastima que quizas por una tonteria que se puede resolver salgas de ella. nada es perfecto en la vida ni nostros jajaja mas no nos hechamos al zafacon simplemente por la primera enfermedad que nos de amiguita, cuidate
Mar 09, 2009 | Euro-Pro 534DX Mechanical Sewing Machine
MAQUINA DE COSER BROTHER
Vérifiez cet emplacement. Il y a des images de chaque machine là. Tout le Q& ; Réponses dans la langue simple, aussi bien qu'un GRAND cust. appui. (son un frère après tous !) J'ai trouvé des manuels de téléchargement là aussi bien.
http://welcome.solutions.brother.com/bsc/public/Model_list.aspx?reg=us&c=us&lang=en&titleid=36
J'espère que ceci aide ! Couture heureuse !
Dec 02, 2008 | Brother LS-1217 Mechanical Sewing Machine
Necchi 3537 Mechanical Sewing Machine Logo
295 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Derek Massey
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
