What cables do I need
I am buying a Samsung 37A456 37'' LCD TV with HTZ2310R surround sound system. What cable do I need and are there good ones and bad ones HELP
    Problem Solver:
I would suggest rca hdmi cables
Posted on Feb 23, 2009
Samsung tv to panasonic sa bt100 home theatre
it is the problem with the hdmi cable .. dont buy cheaper cables it may damage after some time
Aug 24, 2012 | Audio Players & Recorders
I need help , hooking up my samsung HT-Z410 HOME THEATER, TO MY LG HDTV, SO THAT WHEN I'M WATCHING REGULAR TV THE SOUND OF THE TV CAN COME OUT TRUE THE HOME THEATER SPEAKERS, CAN IT BE DONE? CAN A COMCAST...
first of all here is a link to the manual....http://downloadcenter.samsung.com/content/UM/200802/20080220095448484_HT-Z410-XAA.pdf and yes it can be conected thru your comcast but you wil need to buy probably cheapest at wallmart an RF Modulator (Less than 20 dollars) and from your cable box (vidieo out, or to tv) install the cable to the rf mod unit (ant in) and that converts it from coaxial cable to rca (meaning a cord with yellow ,red,white push on connectors) plug the red and white into aux input on surround system (see #3 on manual view on backside of surround unit)and and you got it.It your tv does not have a yellow vidieo connection (which is where the the yellow plug into tv)in the back then add a coaxial splitter after the comcast box so that the 1 coax line goes to tv and the other coax goes to the rf mod then thru RCA cables to the surround sound.you may need to buy xtra cables but they are cheap. hope i helped........you may try asking family or friends for the above equipment i described.the newer tv's dont need it and many people have this stuff layen around...good look
Jan 18, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
I want to hook up a higth def. cable box to asoround sound jvcTH-M505 with no hdmi,( the cable box does have it )and a samsung 46 in series 6 model 610 lcd. I can get soround sound from the movies from the...
There are a couple of different ways you can do this but this is the easiest.
Items needed - One set of RCA audio cables (Red/White)
1) On the back of your TV there should be RCA plugs marked as "Audio Out". Connect the RCA cable to these connections Red cable to Red connector and White cable to White connector.
2) Locate on the back of the surround sound system the connections marked "Audio in (VCR)". Connect the other end of the RCA cable to this connection Red cable to Red Connector and White cable to White connector.
Now to get the sound to play press the "VCR" button on the surround remote and you should get the cable box sound on the surround system.
Good Luck.....
Jan 19, 2010 | JVC TH-M505 System
Surround sound dvd player/tv channels are fuzzy
Hi I have an RCA Truflat TV and a philips Surround sound dvd all in one system and a jvc dish system. I have had my surround working up until my nephews messed with it and hooked up a wii system to it. Now I get no sound on my surround sound and I have tried rearranging the cables but I can not get any sound from the surround sound and for the life of me I can not rember how I originaly had it set up. can you help?
Jun 24, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
How to hook up wii to surround sound
Put all the wires to the tv. Now you need another A\V cable (yellow, red, white) only use red and white from, audio out on tv to audio in on surround system and set it to TV. OR Put the red and white from Wii to surround system and the yellow to the tv. this way you have to use surround to hear it. The other way you can use the tv or both. The first way is ideal if you have an extra cable.
Mar 15, 2009 | Nintendo Wii Console
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Ihavea 37'' dynex lcd and want to hook up a samsung home theater
cable box needs to be dolby digital to allow surround sound to work
Dec 26, 2008 | Samsung HTZ-510 Theater System
Getting surround sound from tv
The only way to get the surround sound by your set up box to your system by audio connections ok other than you cannot get from TV surround sound.
Dec 21, 2008 | Philips HTS3450 System
Need hook up diagram for Samsung HDTV using HDMI with Cable box and Samsung 5.1 Surround Theater System
you can run a fiber optic cable out of the tv into the surround system if the sytem has a fiber optic input, or your tv should at least have red and white rca cables for audio out, then you just pick any input on the surround sound and any audio from dvd players ect thats hooked up to the tv will be sent through that one input on the surround sound. The only thing you'll have to do is turn the volume up or down on your sound system.
Jul 09, 2008 | Televison & Video
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Dec 24, 2007 | Samsung HT-X50 System
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
