Question about KitchenAid KEMC377K Convection / Microwave Oven
I just changed the buld out in my superba microwave. It stayed lit even with the door closed. The bulb is no longer working, but neither is the microwave. I get a DOOR message. The door latches work correctly and the microswitches appear to be fine. What is wrong?
  • 93 Answers
There is normally 2 swicth in the door actuater one may be def or sticking check them out
Posted on Mar 15, 2009
Why my Daewoo microwave oven blows the fuse only when the door gets closed while when it startre with the door opened the bulb is lit and so is the control board until the door is closed then it blows
Hi. The fact that the fuse blows when the door is closed is quite logical. There are safetyswitches preventing the oven to start with an open door. As to the fuse blowing, There are 3 possibilities: the High voltage trafo is defective, the voltage doubler diode or the capacitor are defective. You must be VERY CAREFULL when working on these parts: the voltages are LETHAL.
Aug 25, 2014 | Daewoo Microwave Ovens
Hi!! My Kitchen Aid superba microwave oven says door and the door seems to work okay. Any suggestions?
the micro switch is probably faulty which tells the machine the door is actually closed or open. this would need replacing which means pulling the unit apart.
hope this helps
Aug 20, 2010 | KitchenAid Microwave Ovens
Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Dec 22, 2009 | KitchenAid Microwave Ovens
Have a Whirlpool RMC275PD microwave. Light bulb
no, no, no,,,its far to dangerous for you to open up the case of your microwave to change a light buld,,,
dont even think of going in there,,,
inside your microwave there are 1000,s of volts stored up in a capacitor if you tuch it you could kill yourself
have you ever seen a police stun gun working,,
it realy hurts you,,,,,
inside your microwave is the stun guns big brother
it dont just stun you,, it could kill you,,,
thats why you dont go inside it ok,,,
the light buld can be changed from inside the case normaly if it cant be, then drop it in the shop for a repair or use it with out a light in it,,
dont try and kill yourself just for a light buld
Oct 31, 2009 | Whirlpool RMC275PD Microwave Oven
How to change light bulb? The light that goes on when the microwave is working burned out. How do I change it?
remove the vent cover on the top of the unit above the door
two srews should be holding it down from the top
slide the vent off
you should see a mtal plate
remove that and the buld should be underneath
Oct 27, 2009 | Kenmore 63672 Convection/Microwave Oven
Advantium Bulb replacement
You are describing the little bulb in the front. The speedcook light is a different bulb
See: http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Apr 12, 2008 | GE Advantium SCA1000H Convection /...
GE XL1800 Suface light
This is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jul 21, 2007 | GE XL1800 1100 Watts Microwave Oven
KitchenAid KEMC377K Convection / Microwave Oven Logo
261 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
