Question about Onkyo TX-NR905 Receiver
CRATE PA-B6350 no output
I just bought a used CRATE PA-B6350 and hooked it into 2 peavey 15" bass cabinets and there is hardly any sound output and the red light comes on and the sound that does come out is distorted. what could the problem be?
The 2 speaker jacks are wired in parallel. If your subs are 4 ohm rated the amp is seeing a 2 ohm load and may be trying to protect itself - hence the red light. I would suggest you unplug 1 of the subs and see if the problem goes away. You may have a problem with one of your subs. This amp is probably not the best choice for such demanding work as it is not fan cooled. Good luck.
Posted on Aug 15, 2009
Peavey sp2 pa speakers quit working
Ok,
First of all i need some more information, such the power amp you've hooked to them rating in watts and please specify if you are not getting sound from tweeter or 15" BW speaker or both of them, this way i can improve accuracy helping you out.
Feb 03, 2013 | Peavey SP2 PA Passive Speaker
I just purchased 2 old Peavey SP-2 and SP-3 speakers. How do I wire from the crossover to the speakers so the horns and 15's are wired in correct.
These cabinets are self contained and you do not use a crossover with them. The speakers do NOT come out to separate connectors. You just drive these with an amplifier. DO PAY ATTENTION to the power rating... you are safe using an amplifier with a MAXIMUM of 150 Watts RMS per speaker cabinet. More than that and running them loud and you will be replacing the speakers. These will cover a 40 foot square room at comfortable level.
Aug 14, 2011 | Peavey SP2 PA Passive Speaker
What was the glowing inside my peavy pr 15 pa cabinet when I turned up my treble on my pa amp by accident? There was no damage I was just curieous as to what that glowing was
There is a speaker protection circuit that uses a lamp that will light IF you are driving the spoeakler TOO HARD !!! You can search for "Peavey speaker protection" circuiot online.
Jun 13, 2011 | Peavey XR 8600 / PR 15 PA Package
I have a Crate PA-8 4 ohm 150 watt PA head that I run to four Peavy 10" PA speakers (two per side in series). It was very good, clean sound, but the speakers were cheap and may have been pushed too hard -...
150 watts should be easily handled by four Peavey speakers in the connection you described.. If the Peavey's are 8 ohms, then your total load was 8 ohms for the series/parallel arrangement which is well within the 2 ohm drive capability of the Crate according to specs.
I question if you really mean the speakers were in series? This requires a special cable to do this. Now if you mean they were "daisy chained" like the amp went to one speaker and another cable connected that speaker to another, then you REALLY had ALL speakers in parallel electrically which would be at the 2 ohm low limit of the amp... In either case, with only 1/4 of the 150 Watts to each, the speakers should NOT have been damaged. The amp MAY have been damaged. Try each speaker individually at a REASONABLE level to test.
If you plug into the effects loop out jack,OFTEN the connection to the internal power amp is broken so you might have to arrange a special cable as a wye to go back into the power amp as well as your external amp. In any case pwere ALL interconnected amps, etc from the same power source/receptacle for system safety.
Jul 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate Bass Amp B100 - No sound.
Do you happen to have another speaker that you could hook up to speaker output? This would bypass the amps internal speaker and lf you get sound from that setup, it would mean either a jack failure or possible internal speaker problems. Please let me know.
Jan 24, 2010 | Crate Music
Can you directly hook a sr16 to a peavey bass speaker cabinet using the output mono on the sr16 to send or retrn on the cabinet?
You can, however a bass speaker cabinet will NOT handle the higher pitch sounds needed for cymbals and snares, etc. You would connect it to the return AND doing so would DISABLE the other inputs of the bass speaker cabinet.
If you want both a guitar and drum machine into the cabinet, you need at least a small mixer or a speaker cabinet that can take two channels input simultaneously.
Plugging into the "return" of the cabinet DISCONNECTS the power amp from the preamp section in the cabinet.
Nov 09, 2009 | Alesis Sr 16 Stereo Drum Machine
Peavey eurosys 500 watt 4 ohm pa speaker fault.very low volume.
Sounds like the basket has gone on the driver not sure if they are replaceable or if you will have to replace the entire driver, had the same problem on my impulse 1015, cost about £100 from a peavey dealer.
Dec 04, 2008 | Peavey PVM 22 Microphone
Ive bought a Peavey 1500 pa amplifier and would like to know are the a b knobs on the front treble and bass.If they are how would I take the outputs at the back of the amp to my Soundcraft mixer.
The Peavey A/B controls are output gain controls. Your mixers stereo output goes into the amps inputs, channels A & B. The Peavey is the output stage to your speaker system. If you you connect the outputs from a power amp to the inputs of a mixer you will blow the mixers input stage, amongst many other things and possibly damage the amplifier too. The bias (Bass, Mid, Treble controls) are on the mixer, not the amplifier. Unless you are using a mixer amp, which you are not. A PA system DOES NOT work in the same way as an intergrated hi fi amp.
Nov 07, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Onkyo TX-NR905 Receiver Logo
916 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
