Question about GE DSKP233EWWH Electric Portable Dryer
Maytag electric dryer LDE8704ACE squealing LOUD. Changed belt and rear drum wheel support, blower wheel. New blower wheel squeals slightly when turned right. Shot drop or two WD 40 and seemed ok. Worked ok with intermitant squeal a on 1 load but dried load. 2nd load did not dry squealed on and off but just stopped with clothes damp. Now won't start, buzzes when start button pushed. Same buzz like when load done. After all this opened up and new belt seems shaved some. Seems to squeal or whatever between blower and pulley.
SOURCE: Squealing Noise from GE DBSR453GBOWW
front drum bearing and guides
Posted on Apr 20, 2009
ginko
  • 19396 Answers
SOURCE: Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 06, 2009
  • 4090 Answers
SOURCE: squealing dryer
it may also be a bearing, you have to remove the outer cover to access the workings
Posted on Aug 17, 2009
SOURCE: Kenmore 417.81042000 Electric dryer has loud squealing sound
My dryer of the same model number had the same issue. The teflon/plastic wear points are worn out or have fallen off. They are about $22.00 plus shipping at the site below. Disconnect the power, lift (with force) the top off at the front of the dryer and you will have access to remove and replace.
Felt glide assembly - Upper felt seal with three glides attached. Comes with adhesive.
Part Number: AP2150497 made by FRIGIDAIRE
www.appliancepartspros.com/modelsearch_model.aspx?part_id=2150497&&model_id=301211
Posted on Aug 30, 2009
  • 113 Answers
SOURCE: GE dryer dbsr453eb3ww making very loud squealing
You probably have worn front bearing slides, 316 and 313 in the diagram. You may also have a worn rear bearing 3106 in diagram. Slide putting knife between front panel and top near edges to release clips to gain acess to internals.
Posted on Oct 01, 2010
Maytag performa model PDET910AYW--sounds like a belt that needs dressing--loud squeaking sound at times but at other times no sound at all What can this be?
its the drum rollers at the rear of the drum inside the machine,they get dried out from the heat and do capture some lint,then they squeal and chatter,you need to remove the front cover and drum belt and drum to access them,then remove e-clips that secure them to the spindle they ride on and clean out both spindle and wheel center,lightly oil with a very small amount of a dry lube like silicon and replace also do this to the idler pulley as they can also squeal while you have it apart
Aug 22, 2011 | Maytag Dryers
LG dle3777w emitting a high-pitched squeal
Hello there and thank you for choosing fixya
If your dryer is making a squealing sound or a high pitch noise please look at the following
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
May 17, 2011 | LG DLE3777 Electric Dryer
Maytag MDE5500AYW 220V Electric Dryer. Makes a
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
Mar 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag LDE9804ACE has a loud squeal when first turned on. The squeal disipates after a few minutes. Any answers? Can I fix this myself?
This could be your drum rollers, or (less likely) your blower wheel. depending on how handy you are, you can change the rollers yourself. After you make sure that the dryer is unplugged, take the door off by taking the screws out, leaving the hinges with the door. the door lifts up slightly and tilts out. then remove the screws from the opposite side of the opening to remove the "front panel". after the screws are out, the panel hinges at the bottom of the unit. Next you have the "front bulkhead". This is held on by 5/16" screws. There are 4 of them, also the door switch is attached to this part and must be carefully removed before taking the bulkhead off. Next is the drum. this just lifts up slightly and out, but the belt is wrapped around it and should be removed prior to taking the drum out. Note the routing around the motor and idler pulley. Taking a digital picture of the belt routing will help with reassembly. once the drum is out, you will see the "rear bulkhead". at the bottom, in the 5 o'clock and 7 o'clock position are your noise makers, the drum rollers. Replace these and reassemble in reverse order and you should be good to go. While you are in the disassembled dryer, putting a little silicone grease on the idler pulley shaft will help it last longer, and vacuuming the inside will help too. Hope this helps!!
Dec 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag performa dryer model #pdet920ayw and when i turn it on it squeels.
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
The most common cause of a squeal is the drum roller, of which there are 2. It is usually a good idea to replace both rollers, roller shafts and drum belt at the same time, as they have a tendency to wear at the same rate. You must also use the proper lubricant on the roller shafts, (Syl-Glide), or you will have a recurrence of the squeal.
1. Drum Roller Image
http://www.repairclinic.com/SSPartDetail.aspx?s=t-pdet920ayw-%3d%3di966673&PartID=966673
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
You can also obtain more appliance information at my website, www.homemanagement.services.officelive.com
Aug 27, 2009 | Maytag Dryers
Dryer squeal @ start up; access
It sounds as if you have a dry rear drum roller. Check the above link first for parts and teardown.
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Model no. LDE8506ACE has a noise when running seems like maybe drum rollers or belt. how do I get to drum?
This link is provided by www.repairclinic.com and shows parts breakdown/disassembly procedures, etc.
A faulty blower could also cause a noise during operation and as the motor slow rpms on stopping.
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Aug 18, 2009 | Maytag Dryers
Sqealing
If your dryer is noisy, check these: Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
May 12, 2009 | Dryers
Maytag electric dryer (LDE9806ACE) Tumbler sqeaks/squeals when first turned on
Two issues to look at. One dryer belt idler pully arm. Second actual motor may have bearings acting up. May need to change both to eleminate problem.
May 19, 2008 | Maytag Dryers
GE DSKP233EWWH Electric Portable Dryer Logo
264 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
