Question about Mercury P4VM800M7 Motherboard
Hibernation my motherboard is mercury 865.it does not goes on hibernare and stand by mode. during hibernation and stand by mode the computer get restarted.plz solve my prblm
    New Friend:
  • 99 Answers
Your problem your oparating sytem.Reinstall it then solve this problem.
Posted on Dec 09, 2009
Sir i changed the ram for my mercury 865 after replaceing its not getting started and then i try with the old ram same prob plz help me ali....
hi friend, i think your new ram created a problem with your motherboard. remove your motherboard battery for 15 minutes. then, place it and after it you go for your old RAM. if it again create a problem.so, go for nearest service center. they will surly fix problem.
Regards: Rakesh
Feb 05, 2011 | Mercury Computers & Internet
When I close my laptop during normal use, Instead of going into hibernation as normal, the screen just goes blank (with the laptop still running). However I cannot resume the computer and have to just turn...
hi when you close your laptop it goinng to stand by mode if you press any key it should resume. you can change this options in control panel, power option then go to advanced tab. By the way hibernation need to be enable and is different than normal shout down. if you need more help let me know.
is it help please rate it
regards
Sep 06, 2010 | Computers & Internet
Question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
Cooling fan runs constantly coming off stand-by
Has it always done this or is this a recent problem?
Try this: right click on your desk top's start screen, select properties, select screen saver, select poweer, select hibernate. Make sure that hibernate is checked and select apply. Now when you hibernate your computer will remember all the info you were working on AND it should make the fan run normally on start up.
Not all computers have the hibernate feature and it cannot be added, so let's hope yours was built with it at the factory. Good luck!
May 01, 2009 | Computers & Internet
Computer is not starting up in standard windows mode. dell media keeps popping up and when i exit the program my pc shuts down. i tried ctrl and f8 it brings me to a short menu. (1) continue restart...
Are you running Window XP? Is your computer set to hibernate? If so, you may have a hibernation error...
If I understand correctly, while pressing F8 during bootup you received a message that states:
"System restart has been paused:
Continue with system restart.
Delete restoration data and proceed to system boot menu"
You may wish to read this article about the error. http://support.microsoft.com/kb/294427
Then, go ahead and do that second option. What hibernate does is write a big file to the HD with the exact state of Windows. That is a "restoration" file. If hibernate doesn't work, deleting the restoration file will often allow the computer to restart normally.
Good luck! Please post back with your results.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 31, 2009 | Dell Inspiron 1420 Notebook
About laptop
Generally you can just hit the space bar a couple of times, and that should bring the machine out of Standby mode. However, if it is not Standby but Hibernate mode, you usually need to push the power button to bring it back from Hibernate.
You can adjust these and other power settings by going to the Control Panel, and clicking on the Power Options applet.
Feb 11, 2008 | Computers & Internet
Stand by icon locked Toshiba Satellite 1115-S103
i really need more info, two things:
firstly look to see if the clip (where the screen clips onto the base when it closes) is mobile and is not jammed down from something.
secondly restart, if a image comes up in your POST (when the computer boots up) push tab and then F8 or similar (it will say just read the screen = ] ) and restart windows in safe mode.
when you have booted up in safe mode check in the display and power window and tell the computer to never go into sleep or hibernate.
like i said i need more info cause this can also be caused bu a hdd contact error, or a battery falure, so please if this does not help in the slightest just post up here more info and i will be happy to help further.
good luck.
Oct 29, 2007 | Toshiba Satellite 1115-S103 Notebook
Boot failure pentium 4
here is a temporary fix, but you may like it as a permanent one. Use the Windows hibernate mode. It actually works every time! Windows makes a "System screen shot" and stores it on hard drive and then powers off. Just be aware that you must ensure enough hard drive space for this. I am using this mode every day now. I think your system is trying to reject the power-saving features selected in Windows or at CMOS settings. Try turning off (or disabling) one feature at a time. I still think hibernate is the way to go. Here is a useful tip: to force hibernate (after it has been enabled) select START-SHUT DOWN and hover over STANDBY button and then hit the SHIFT key. The STANDBY button will turn into the HIBERNATE button. This is a quick way to enter hibernate. Remember to enable SYSTEM RESTORE mode so that if anything goes wrong during this "experiment", you can easily restore Windows system. I also use RESTORE but I also "clean house" once a month by turning it off and Disk scan and defrag and turning it back on.
Jun 24, 2007 | Intel D845WN (KD845WNPAK10) Motherboard
Mercury P4VM800M7 Motherboard Logo
127 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
vsri9
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
