Question about Frigidaire Dryers
Its eating sosks they get stuck in front barrel it seems like the tub is a little loose.
  • Frigidaire Master
  • 3,361 Answers
Your dryer drum supports front and rear are worn and must be replaced.
Posted on Feb 21, 2009
I have a model GHW9150PWO. I have plastic shaving behind front rubber and the plastic around the drum is all chewed up. The barrell appears loose. I'm fairly handy and I want to know if this is...
Hello, Thank You for using FixYa. I will be helping you today.Check that the pulley nut in back did not come loose..If it is tight you may need to replace the spin basket And tub.Also make sure when the center pulley nut is tight there should be no play in the pulley or spin basket.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Drum bangs while turning
if the tub is banging all around and very noisy in the spin cycle it's time for a new washer.the spider gear is broken,this happens from using to much detergent,the front load washers use very little water so you should only be using very little detergent and it should be H.E. detergent.the spider gear costs around 500 bucks and the detergent eats at it like acid,let me know how you make out
Aug 29, 2010 | Frigidaire ATF6000ES Front Load Washer
Tub has a wobble in it . front seems loose.
Could be loose bolt @ back of pulley or Drum bearing gone which makes drum very noisy on spin expensive to fix..
Oct 03, 2009 | Whirlpool GHW9100L Front Load Washer
I bought a used dryer (model # fde336res2, serial # xd01501804)The dryer works, needs a knob but it also eats my clothes. It seems to be a problem between the barrel and the front panel. The clothes get...
Your problem could be caused by a bad felt seal..the drum rotates against this seal. The purpose of the seal is to seal the hot air from going out of the drum and into the room.
Remove the front of the dryer and this should expose the drum and felt seal.
Sep 25, 2009 | Frigidaire Dryers
Theirs a pellet stuck in the barrel and no matter what, i cant get it out
Get a wood dowel that will fit snugly but still loose in the barrel. Spray a little PB blaster in the barrel and let it sit on the pellet for about 30 minutes,then use the wood dowel with a small mallet to drive the pellet out.
Sep 01, 2009 | Crosman (4032)
Barrel will not spin, sounds like motor is running.
check the p-trap for stuck loose items---change,rocks,etc.. I had the same problem and the technician said the placement of the p-trap causes lots of loose items to get stuck, which causes the washer not to go thru its cycles & won't spin.
Apr 05, 2009 | Frigidaire ATF6000ES Front Load Washer
LG wm -1832c front loader making noise
when you take the panels off you will see that the barrel is suspended by springs on top and fake struts on the bottom. be careful when removing the panels. if the barrel is leaning forward it's the front struts, if it's tilting upward it's the rear. and be careful how much you load in a front loader
Feb 17, 2009 | LG WM-1832C Front Load Washer
Gasket came loose and rapped around laundry-tub seems loose
if your metal ring (clamp) came off it is most likely due to you shocks or the spring at the top are worn out and need to be replaced. this will happen more often if the cycles are off balance or the washer is over loaded
Nov 26, 2008 | Whirlpool GHW9400 Front Load Washer
Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
Jun 24, 2008 | Speed Queen AWS75NW Top Load Washer
Elastic eating front load washer
Check the inside drum vanes. Sometimes the vanes may crack and grab certain items.Next check the front of the drum and tub for any loose items like wires from bras or curtains sometimes these may get stuck in the drum or vane and cause this problem.Also check your soap make sure there is not alot of suds this is my number one problem with these machines.H.E. soap is best but watch liquid tide it's been sudsing alot.
Oct 03, 2007 | GE WSXH208A Front Load Washer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
