Question about HP Computers & Internet
My touchpad mouse on my HP dv71247cl is skipping
Hi there...I've only had my HP dv71247cl for a week, but from day one I have noticed the mousepad is very ''skippy''. I have used laptops for years, and realize that sometimes you can touch the pad with another finger without realizing it which causes the cursor to sort of skip to another position. This is what is happening, but I am sure I am not touching the pad with more than one fingertip. Is there a way to calibrate the mouse?
  • HP Master
  • 2,302 Answers
CP ., go to control panel
click mouse
Posted on Jul 05, 2017
SOURCE: Keyboard Cursor Jumping
I have been having the same problem for some time now with my Acer laptop and windows vista.
What worked for me was changing a Mouse setting in the Control Panel.
Go to Control Panel -> Mouse. Then go to the "Tapping" tab and make sure that the "Tap off when typing" box is Checked
Posted on Feb 11, 2009
SOURCE: Laptop touch pad doesn't work properly
Here is what I did to get the touchpad to start working again. My laptop is Gateway and a couple years old, running Windows Vista.
1. Start>Control Panel
2. Double-click on Mouse icon (or button, depending on how you're systems set up).
3. When a the Mouse Properties window pops up, choose the Device Settings tab.
4. Click on the Settings... button.
5. A new window pops up and on the right side there is a list of options - choose Tapping.
6. Once clicked, there is a check box that allows you to Enable Tapping.
7. Click OK to close out your windows and the tapping option should be enabled on your touchpad.
Hopefully this helps.
Posted on Apr 14, 2009
kd6rhd56
  • 400 Answers
SOURCE: Laptop keys jump around
First check to see IF u have a virus, affecting the memory,and hard drive. then check the keyboard/mouse sensitivity . then have it cleaned.
Posted on Jul 14, 2009
SOURCE: dell inspiron touchpad
just had the same problem.mine was caused by a new charger or over charge.removed the mains power lead and all went back to normal.
Posted on Sep 23, 2009
SOURCE: laptop touch pad mouse does'nt work while charging
my toch pad dont work when my laptop is charging i have inspiron 1525
Posted on Oct 23, 2009
Hi, i hav a probook 4510s laptop & i cant get the mouse pad to work... when the lappy is starting up, in the left hand top corner is says - no mouse detected. please help!
If this is a recent occurance, shut down, unplug, remove battery, plug in, push the on/off button and do a System Restore to a date before this problem. Perhaps the TouchPad driver is in error. You can try a external USB mouse to troubleshoot the problem in Device Manager to verify the driver or device isn't in error. I think HP TouchPad software is Synaptics Pointing Device, check your your Tray Notification Area for the icon, right click, select Pointing Device Properties. Or Control Panel, select Mouse.
Nov 29, 2013 | HP ProBook 4510s FM849UT Notebook
Laptop cursor won't stop clicking
If you are using an external mouse maybe thats whats clicking
Otherwise you could popup the keyboard up and disconnect mousepad ribbon(the small one) and see what this does for you
Aug 05, 2013 | HEWLETT-PACKARD Computers & Internet
Hi how to switch on mouse pad?
there's a button just above the mousepad but usually the problem isn't the button it's the driver or the mousepad is broken. use a usb mouse (they're really cheap) and run windows update until there's nothing left to update. if that doesn't work it's either a loose connection or a faulty touchpad. they aren't the most difficult laptops to repair but if yu're a novide i'd pay someone to do it
Jan 10, 2011 | Compaq Presario CQ60-220US PC Laptop
My mousepad (touchpad) will not respond. The
I recommend going to Acer's support site and downloading the updated drivers for the mouse/touchpad. This should restore your functions.
Good Luck
C2Solutions
Oct 18, 2009 | Acer Aspire 3000 Notebook
Disable mousepad
hi,
try the Fn+F7 combo, the F7 is usually assigned to the touchpad and is indicated by an icon that's relevant.
This works on most notebooks to turn on or off the touchpad.
. Press F2 or F10 (it varies) to enter your bios setup screens. In these pages is a setting for touch pad only, mouse only or touch pad and mouse or serial. You might check that.
Jul 05, 2009 | Dell Studio 1537 Notebook
Mouse arrow is skipping around when I move the mouse.
have you tryed cleaning your mousepad the slightest little bit can make it skip around because mine does it often and i wipe it with a dry cloth normally works :)
May 15, 2009 | Computers & Internet
Is there a way to turn off the mousepad of my HP?
Yes. There is a button just above the touchpad
Mar 05, 2009 | HP Pavilion dv6000z Notebook
How to disable touchpad?
just above the touchpad you will find a small button just press it .and you will notice it is disable so no need to do any changes from control panel.if you want to enable it again press the button......
_______________________________________________________
Was this solution helpful .Show your appreciation by rating it.
Thanks for using fixya support. You have a wonderful day..
Jun 06, 2008 | HP Pavilion dv4000 Notebook
Mouse pad wont work after water spill
not difficult..with right tools and patience..the touchpad is part of the upper assembly, and requires that the bottom be removed. When I do this, it takes around an hour.
got backup?
Feb 20, 2008 | HP Pavilion ze2000 Notebook
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
351 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
