Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Can't get agitator off of GE spacemaker model WWP 1180G
I tried unscrewing the top cap and pulling on the agitator to take it off and remove a stuck shirt, and it won't budge. I pulled very hard and tried using a belt to pull on it too. The model number is WWP 1180G and, i'm not sure how old it is, but it looks to be about 5-10 years. Any advice would be appreciated. Thanks.
  • 2 more comments
  • bradi259 Feb 21, 2009
    there is a bolt inside when i remove the cap.
    still no luck. thanks for the help
  • bradi259 Feb 22, 2009
    the bolt is closely surrounded by a plastic ring - i can't find a tool to fit it - what tool do you need for this?
  • Paulo May 11, 2010
    When you removed the top cap off the agitator did you see a bolt inside? If not do you see a white plastic piece with a square shaped hole?
  • 188 Answers
There is a bolt, ok. Remove the bolt and lift the agitator by reaching underneath it with both hands on each side and pull it up. If it seems really stuck, apply some WD40 and let it soak a bit before trying to pull it again.
Posted on Feb 21, 2009
  • GE Master
  • 3,361 Answers
Once you unscrew the top the agitator should lift off.
Since it will not, you should soak the screw on top of the agitator in wd-40 or similar product to dissolve the corrosion that made it stick.
How do I get a mattress cover stuck under agitator out?
On the older machines, the cap on top of the agitator unscrewed & then the agitator could then be raised.
Sep 13, 2014 | Washing Machines
How do i remove the agitator
Top of agitator has a removable cap. Try to unscrew, if not pry off. You should find a hold down nut underneath. Remove nut, then pull evenly the agitator.
Sep 01, 2014 | GE GTWN2800DWW 3.9 cu. ft. capacity top...
Clothes stuck under agitator
I would try to get clothes out, even if destroyed first. Otherwise,
there is a plastic cover cap on the top of the agitator. remove
by unscrewing or prying off. Hold down nut is exposed and remove
carefully, gently and with a ballanced pry up from underneath to raise agitator.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
How do I remove the agitator on my GE Spacemaker model GSLS1100?
Remove Pulsator (Blue) cap,Pulsator nut, Pulsator, and 2 washers and 1 nut. Pull up on the drum. But, 1st ask yourself WHY you want to remove the agitator!
Jul 02, 2014 | GE Spacemaker WSLP1100D Top Load Washer
Water is draining very slowly out of the washer and if it takes to long it gives a code of DR
Hi
It seems that something is stuck and you'll have to remove the agitator to clean it. I f this is an old style washer, then it should have a bolt under the cap that must be removed to remove the agitator, then grab hold of the agitator and lift up. If it's a not too old then the agitator just pulls out, remove cap, if no bolt, just grab hold and lift up hard...picture. You can also clean the drain hose as that might be clogged if the agitator is fine. Hope this helps...please post back for further assistance.
Daniel
Jan 10, 2011 | GE Spacemaker WSLP1100D Top Load Washer
How to remove agitator from GE washer? Model WHDRR418G1WW.
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
GE washer whdsr315 will not agitate, everything else OK How do I get at agitator
Pull off the softener cup
pull of the cap underneath
unscrew the bolt
pull up on top of agitator...it might need persuading
Nov 02, 2009 | GE WBSR3140D Top Load Washer
How do I remove the agitator from Whirlpool model LBR5133AW1?
Open the top of your washer and remove the cap on top of the agitator. It might be stuck, so you'll have to try turning it couterclockwise to unscrew it from the agitator.
There is another cone shaped cap under the top cap that you have to remove also. This might be stuck, so wiggle it back and forth to loosen it and pull it straight up and off. You can use a flat bladed screwdriver to GENTLY pry it up, if it's really stuck, but be careful so you don't damage the cone cap.
Once you've got that off, there is a screw or hex headed bolt that holds the agitator on the shaft. Remove that and the agitator should be able to be rocked back and forth while pulling straight up to remove it from the motor shaft.
There are other parts inside the agitator, but you shouldn't have to remove them from the agitator in order to remove the entire agitator assembly.
Here's a line drawing that shows your washer's agitator and wash tub to help you better understand the sequence and order of the parts involved. You can also use the searspartsdirect site to order any replacement/repair parts you might need, if you don't have a local appliance service center that carries them.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=LBR5133AW1&productCategoryId=0153000&brandId=1198&modelName=AUTOMATIC-WASHER&diagramPageId=00003&componentDescription=AGITATOR,%20BASKET%20AND%20TUB&documentId=O2022909&backToLink=Return%20to%20subcomponent%20list
I hope you find this Very Helpful and best regards!
Sep 21, 2009 | Whirlpool Washing Machines
Need to remove agitator
IF THIS IS AN OLDER UNIT THE AGITATOR WILL BE SEIZED TO THE SHAFT ODDS OF GETTING THE AGITATOR OFF ARE VERY SLIM. IT SOUNDS LIKE THE NUT UNDER THE CAP IS SEIZED ALSO YOU SHOULD BE ABLE TO REMOVE THE CAP AND THEN USE WRENCHES TO REMOVE THE NUT
Aug 09, 2009 | GE WDSR2080D Top Load Washer
Shirt caught in the agitator
The top of the agitator should unscrew then pull off.
Feb 21, 2009 | GE Spacemaker Washer and Dryer Electric...
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
592 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
