Question about Hotpoint Ultima WF860 Front Load Washer
How to clean the filter
Hi iv got an Ultima Hotpoint WD865A washer/dryer can u tell me where the filter is please!
Thank you
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
The dryer filter is in the dryer box on top of the drum, under the lid of the machine at the rear, sometimes has a grey hose going into it, the box will have to be removed and split to access it.
the wash filter will be either at the front of the machine behind the kick plate or at the rear behind the lower panel attached to th bottom of the drum.
Posted on Feb 25, 2009
My hotpoint ultima dryer has no power to it changed fuse checked plug socket emptied water tank cleaned both filters
power comes in at mains lead goes to the choke /filter from here onto the door interlock switch then onto timer ......hope this helps
Feb 26, 2011 | Hotpoint Ultima WF860 Front Load Washer
Error code F-05 showing on my Hotpoint ultima
Error code F02 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose from bottom of drum.
Remove and clean filter inside hose.
Remove hose on to pump and check for blockage or obstruction here as well.
Pleas rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WD72 Front Load...
We have a washer dryer hotpoint bwd129. Can you
a washer dryer has a different approach to cleaning fluff. It has an internal flushing system.. only do routine check on pump filter.
Oct 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Filter on WT960
hi, in the uk the filter is behind a flap on the bottom/front of the machine, be careful as when you undo it some water will leak out, hope this helps
Feb 09, 2009 | Hotpoint Aquarius WD63 Front Load...
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Cant find filter on my hotpoint Ultima
Good luck. All modern washers that I know dont have the filter you need. If a clean out is needed you will have to clean out the pump.
Jan 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Test
Hi i have a hotpoint wd 860 washer dryer the display is showing f 08 heater relay cannot be activated.can you please tell me how i can fix this problem myself.Thank You
Jan 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washer dryer
ok lay the machine on its side the side with the soap draw under you will find the outlet pipe runing to the pump then another hose going from the pump to the bottom of the drum. if you disconnect the hose from the bottom of the drum you will find the filter remove this hose from the other end and clean the filter and hose with hot water once replaced check the hose in tight it may be tricky to replace stand up the machine and test using water only and an empty drum.
Nov 01, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WT965
Hotpoint Ultima WD72 Front Load Washer/Dryer
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jul 08, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima Washer/Dryer Supersilent....
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
491 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
freddyfox
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
