Question about Altec Lansing ADA 880 Computer Speakers
Ada 880 blowing fuses
Hi, I have an ada880 system. I keep blowing fuses (located in subwoofer).
Thanks
GVC
Good chance a shorted diode on the other end of the pcb where the big wire harness connects.
Four little 1N4001 diodes (D10 through D13 I think) and Two diode bridges (the black sqares standing off the board on four legs).
You need a meter to check them. Any one of those six could be the problem. If it's one on the 1N4001's
then you should replace them all and upgrade to 1N4007's.
I just upgraded some some parts on my ADA880 sub pcb today. Love the sound of this system no longer use it with my computer - have it hooked up to a DVD player with digital out. So basic but so awesome.
Posted on Mar 13, 2009
ADA 880 subwoofer schematic diagram
Mounting is not so critical,
• If it is the same size of the original , replace as it was
On most, it is perpendicular to the PCB
• What important is the polarity,
positive side goes to positive, same with the negative.
sample image:
Source:
http://en.wikipedia.org/wiki/Electrolytic_capacitor
Sep 12, 2012 | Altec Lansing ADA 880 Powered Sub-Woofer...
Mission m-cube sub fuse keeps blowing
If you have replaced with the correct rating and the fuse blows off then you will need to check for higher current drain in the sub woofer or the network. After replacing the fuse load up the subwoofer slowly, reduce the bass and as you increase check at the point the fuse blows off. Now we need to analyse if the rating of the amplifier you are using is rated for the subwoofer. If your subwoofer has a higher rating you can increase the rating by about 25% and check again. Some amplifiers give a very higher voltage on full bass which could result in such a condition. Moderate this and check again. If the fuse stays Ok you can continue with this new rating.Otherwise the output of the amp at higher volume needs a confirmation. Hope this helps. Good day
Jul 20, 2010 | Mission M-CUBE System
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
My Ada 880 speakers work fine, but the subwoofer isnt making any noise....it doesnt seem like its getting power but if the speakers work id assume the fuse is good right? i cant seem to find alot of...
Hi there bud, this could also mean that something in the Subwoofer has blown or shorted, the best thing to do is too take it back too the shop where you bought it and ask them too replace it .its not worth opening it up yourself and losing the warranty...
Happy new year . Hope you come right :)
Jan 03, 2010 | Altec Lansing ADA 880 Computer Speakers
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
Altec Lansing ADA 880 Toroidal Transformer Replacement
Did you solve this? Cause I have the same problem and need some advice...
~Brian
bwalker1978@yahoo.com
Mar 23, 2009 | Altec Lansing ADA 880 Computer Speakers
Fuse on subwoofer keeps blowing
Subwoofers draw a tremendous amount of power. With the amount of heat generated by amperage flow and the movement of the voice coil, you may have burned out the coil. Do a resistance check across the coil. Easy check? Temporarily attach another speaker to replace that one. Use LOW VOLUME and slowly work the vol up,and, if the fuse does not blow, it's the other speaker.
Mar 10, 2009 | Dahlquist ORBIT 5.1A System
Altec Lansing 4.1 ADA880
if you are a technically skilled person
simply clean all the IC(chip) leads, by using a blower or using a painting small brush
the dust come in contact with the other pins that make this problem
Jan 23, 2008 | Altec Lansing ADA 885 Computer Speakers
Subwoofer
do the fuses blow no matter what volume you are sending?
May 25, 2007 | Wharfedale PowerCube PC-10 Subwoofer
756 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
