Question about Kenmore 24642 Top Load Washer
Leaks water Our Kenmore 24642300 top load washer leaks an amount of water on the floor during each washload. The front is not removable. How can I see where the water is leaking? Does anyone know what the cause might be? Thanks.
  • Kenmore Master
  • 3,361 Answers
Probably a bad water pump. That is were the Kenmore usually leaks.
2 screws on the top panel right and left sides.
Remove these screws, tilt the control head backwards.
Remove the wiring harhess connector.
Remove 2 clips holding the cabinet to the back panel.
Remove the cabinet by pulling forward.
Pump is attached to front of motor.
Posted on Feb 21, 2009
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 500 series top load washer. water on the floor during water pump out cycle. This does not appear to happen on prement press cycle, but does happen on normal cycle. Have no tried the heavy duty...
Could be a tub seal leaking (not likely), or water pump leaking (very common), cracked outer tub, leaking hose. You would really need to take washer cabinet off machine to be able to see where it's actually leaking.
Sep 30, 2017 | Kenmore 22422 Top Load Washer
My washer wont drain, says SD and blinks f-21
Sd: Suds lock. Detergent overdose. Clean out the soap dispenser. Remove the bottom panel and open the pump drain. F21: Long drain. Possible cause: Clogged filter, clogged/failed pump. Run some loads without detergent then use these amounts:
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Apr 15, 2010 | Kenmore 43142 Front Load Washer
I have a Kenmore Elite Top Load 5 years old which leaks ONLY during the spin cycles. I beleive it may be water coming over the top of the tub. I need to comfirm and get instructions on the removing of the...
it is the water pump probably it only pumps out and has pressure on it when it is spinning easy to remove just pull it away from the wall a couple of feet and tilt it back lay down on the floor and it is the first thing you see next to the front panel two clips and a couple of hose clamps
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Heavy load small amount of water leaking on floor
you need to remove the back to find and repair the source of the leak and fix it.  If it's new it's a warranty repair.  There aren't any packing straps.
Mar 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer 110-24642300 is leaking when it fills
tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Feb 24, 2009 | Kenmore 22642 Top Load Washer
Small amount of water from washer
ck around pump at place motor shaft connects ..that is mot likely place
Sep 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Kenmore 24642 Top Load Washer Logo
238 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
