Question about Jacuzzi Bath Perfecta EZ33 959 White round high-performance toilet
Jacuzzi Whirlpool toilet EZ33959
This is a new toilet ,but one of the plastic screw has broken allready.where or what brand can I buy to replace the old toilet seat and get a better one..
  • 547 Answers
Any one should fit
Posted on Feb 21, 2009
HI NEED A BOWL FOR THIS TOILET? JACUZZI DON'T MFG.OR STOCK ANY LONGER. HAVE ALL OTHER PARTS BRAND NEW.ANY MFG OK.
Amazon.com: Customer Reviews: Jacuzzi EZ33959 ...
www.amazon.com/Jacuzzi...Two.../B0027E6AFG
Amazon.com, Inc.Jacuzzi EZ33959 Perfecta 1.6 GPF Two-Piece Round Comfort Height Toilet with Seat, White ... not unique to this model, but we're not happy using the toilet bowl brush ever other day. ... Two have flush levers (handles) that fall off in your hand.
Nov 24, 2015 | Jacuzzi Home
Toilet tank fills slowly
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
My jacuzzi toilet won't quit filling, I have adjusted the fill valve and that hasn't worked. I read a post about a small metal clip below the fill valve, mine is red plastic but it fell off when I...
You gonna have to replace the whole fill valve mechanism. Go to the hardware store and get the Korky brand, because they work like a champ and they are super quiet. Don't buy Fluid Master because they clog easily and are junk. Learned that the hard way after having to 3/4 of them on a 42 unit apartment complex.
Sep 13, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Jacuzzi sent me new rubber gasket for attaching flapper assembly to tank-(held in place with a large white plastic nut) Does the totally flat side of the rubber washer face the tank or away from the tank?...
The rubber washer goes to the inside of the tank under the flush valve which gets screwed on with the large plastic nut on the bottom side of the tank. Then the foam gasket fits over the plastic nut which goes into the toilet bowl hole for the water to flow into the bowl. Tank needs to be removed from the toilet bowl.
Aug 31, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Have to replace two new toilets seats,the seats move
Martin, Jacuzzi has a one year warranty on toilet seats so if you have defective seats and they were purchased less than a year it is covered you will have to find a dealer near you, I provided a link for you to accomplish this. How is the seat attached? There should be two plastic screws with a nut on the underside which can be tightened these tend to loosen and nee re-tightening every so often. I hope this has helped. Thanks for using FIXYA, good luck and have a great day. Jeff
Find A Jacuzzi Dealer
Apr 07, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Jacuzzi Era elongated seat attachment
first need to buy the longer oval seat so it sits correctly at the front most mounting screws are universal-- go buy thin rubber washers and trim and place between the hinge and bowl than tighten down this will stop slippage but the front if not correctly sitting on the bowl will still cause problems
Jan 22, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
My four scatched my Jacuzzi witha screw driver
There are repair epoxies available from Jacuzzi which you can apply yourself. They are already colored. You will clean it well, dry it, and apply the epoxy with a small plastic flatedge which will surprise you at how good it will look. Charge the four year old when he/she becomes 18 with interest!
Oct 20, 2009 | Jacuzzi BM06959 White Era?? One-Piece...
Jacuzzi Bath Perfecta EZ33 959 White round high-performance toilet Logo
1,315 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
