Question about Bose Wave Radio
I CANT GET CD OUT BOSE CD PLAYR HELP THANKS RON.
    Brigadier General:
  • 8,619 Answers
Hi!
You need to reset it. Unplug your battery for a few minutes. That will then allow your cd player to run and eject the cd.
Thanks
Rylee
Posted on Feb 21, 2009
I cant insert a CD into my Bose Wave Music System. I think there is a CD stuck there. How do I get it out?
It is very difficult to remove a stuck disc and may require removal of the cabinet to get inside the works. Best to take it to a qualified service shop where they can do it for you.
Oct 09, 2014 | Bose & Wave& Music System
I have an Infiniti I35 with a Bose radio/6cd changer. The CD player gives an E5 error when I try to play a CD. Help. Thanks, Scott
I have an Infiniti I35 with a Bose radio/6cd changer. and it dont have a display what should i do??
Feb 26, 2010 | Bose Audio Players & Recorders
Bose Wave AWRCC2 error message
Which error, you did'nt put it in the post.
Mar 31, 2008 | Bose Wave Radio
How do you remove song from your mp3 4gb sansa sandisk
1. Either your MP3 playr is write protected .
2. there is some problem in firmware .. lode firmware thru cd ..
Jan 15, 2008 | SanDisk Sansa e260 MP3 Player
Connecting a Sony CD changer
set right input on bose 1st what cabels uuse rca in from rca out on sony
Dec 31, 2007 | Bose Wave Radio
Bose wave radio/cd often cd spins but does not play, sometines will correct if I turn unit off and on. HELP tHANKS
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Nov 27, 2007 | Bose & Wave& Music System
Weird gearing sound while playing CD or DVD
send it back to bose in Framingham, Ma for repair. Get loaner from where you bought system.
Nov 02, 2007 | Bose Lifestyle 48 System
Eer 2 message on bose 6 cd player on 2001 pathfinder
you may need bose qualified serviceman to erase the error,you may need a software from bose.
Aug 20, 2006 | Bose Wave music system Multi-CD Changer...
Bose Wave Radio Logo
325 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
