Question about HP LaserJet 4L Printer
HP laserjet 4L parallel to usb vista Jumbled font on test page
I am trying to add my hplaserjet 4L to my new windows vista laptop. I downloaded the drivers from disc for parallel usb cable. I used vista to download driver for old hp 4L printer...it all seemed to go smoothly, until I saw the test page--a jumbled mess!!
  • Anonymous Mar 20, 2014
    I am trying to connect my HP Laserjet 4050tn to my Windows Vista computer. I purchased a parallel USB cable since my computer does not have a parallel printer port. When the USB cable is plugged into the computer, the printer does not install like a typical "plug-n-play", and I manually had to add the printer. There is no communication between the computer and printer and I'm not even able to print a test page. What am I missing?
  • 628 Answers
You mentioned parallel usb. The HP4L only has parallel. Make sure you specify LPT1 as the port you want. Try reinstalling the driver. It should be in the list of drivers.
Posted on Feb 22, 2009
Got a new computer - can't find 4L Drivers
HI,
You can get the drivers from www.hp.com just go to support page and then click on downloads.
Sep 12, 2008 | HP LaserJet 4L Printer
HP laserjet 4L will not print from Windows Vista
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=25486&taskId=115
Here is all the documentation that I could locate reguarding this issue. I don't see a driver for Vista....however you should be able to install or run in compatibility mode.
Sep 23, 2009 | HP LaserJet 4L Printer
Vista will not print to HP Laserjet 5p
I purchased a Dynex USB to Parallel Converter Cable from Best Buy and tried to connect but had no success. I then sent an email to Dynex customer service and received a reply in about 24 hours. The rep provided spot on instructions which I was able to follow to a tee. My 14 year old HP Laserjet 5P is now ready to run until it blows up.
I spent hours searching web forums and only received overcomplicated replies by people who think they are techies, none of which worked. I am 63 years old and not a techie, so if I can do it, anyone can. I have saved the email and will forward this straightforward simple fix to anyone who needs it. My net cost was $36.00 for the cable.
Sep 05, 2009 | HP LaserJet 5p Printer
HP Laser 4L driver for USB port
Not all USB adapters are the same, you need the one that is made for your printer, I would try a different adapter before going too deep, because when you plug it in your computer should see it even without drivers.
Jul 21, 2009 | HP LaserJet 4L Printer
LaserJet 6L with Vista using Parallel to USB Cable
It can be done tested by Thoo personally 6L printer prints well on vista too
The printer end should be connected to 25 pin parallel cable, converted to the USB on the notebook end of the wiring
To solve your printing problems locate vista driver, since i have tested vista works fine on HP 6L printers
make sure you select the correct O/S and assign in to the USB virtual port 05
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
After installing my vista can print perfectly well on test printout
Advise from http://www.bebo.com/andythoo
Technical support specialist: Thoo Wai Kiat
Nov 05, 2008 | HP LaserJet 6L Printer
HP LaserJet II p Plus will not print
I am assuming that you are using Vista. Based on your post/description:
1. the HP Compaq 6710b has no parallel port;
2. the HP LaserJet IIP Plus is only capable of either serial or parallel connection;
3. hence you're attempting a USB to Parallel interface;
4. the printer is installed in your notebook and is set to USB port;
5. from the printer a test print can be performed but not from the Printer Properties in your notebook;
6. all printing jobs initiated from the notebook results in an "Error".
With the above in mind, may I point/suggest that:
a. Windows Vista driver will only enable your HP LaserJet IIP Plus' basic functions to work. It is not 100% compatible;
b. alternately, you can try using the XP installation CD/drivers of the printer;
c. the compatibility issue may be compounded by the USB to parallel interface;
d. the USB to parallel interface may be hampered by a known Vista USB issue;
e. you can try patching/updating the Vista USB driver. Since this has been a recognized issue with Vista, Microsoft has posted a fix for this here or here.
f. verify that the printer does not display a 22 or 40 Error.
If the printing concern has not been rectified after completion of the above procedures, you may need to:
i. download and install HP Universal PostScript Print Driver; or
ii. consider using a wireless print server connected to the parallel port of the printer; or
iii.consider replacing your printer. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | HP LaserJet IIp plus Printer
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Jan 20, 2008 | HP LaserJet 6L Printer
Won't Print
Usb or Parallel cable? if USB the computer should say new hardware found. If Parallel the should be checked to see if enabled.
Aug 29, 2007 | HP LaserJet 4L Printer
HP LaserJet 4L Printer Logo
330 people viewed this question
Ben Johnson
