Question about Intel Motherboard
How can i increase the memory of my dell optilplex sx260, with an intel 845 chip? i only have 8 mb graphic memory
    President:
  • 948 Answers
You can't. The video card is integrated and there is no expansion slot available to upgrade it.
You can increase the total RAM on the computer by adding a larger piece or an additional piece, but this will not affect the graphic memory.
Posted on Feb 21, 2009
Increase the amount of shared video dell gx280
Hello!
Don´t lose time for that, I think that you have integrated grafik in own chip, and they have same options with 1 or 64 MB, option in bios, that isn´t a standard shared grafik. Try AGP card if you have a socet for that.
Oct 30, 2009 | Dell OptiPlex GX280 PC Desktop
Need jumper pin config settings for imperial gv 2003 i need to know what j-5 is for mostly
This MB is very similar to Intel 845 boards. The info is similar & if you had mentioned which jumper's, then maybe.. otherwise this is the specs of imperial:
143159 Imperial GV 20030812
Mat,no:143XXX IMPERIAL-GV200XXXXX E-Machines Socket 478 Processor Socket Type: mPGA478 Memory Type: Unbuffered DDR Synchronous DRAM (DDR SDRAM) Memory Speed: PC2100/PC1600 Memory Sockets: Two 184-pin 2.5 V DIMM sockets Maximum Memory: 2 GB 256Mbit Memory Support: Yes Front Side Bus: 400MHz Intel: Extreme Graphics (845) AGP Manufacturer: Intel Bus: AGP Chipset: Intel 845 Video RAM Type: Uses system memory Onboard Audio Configuration: Intel ICH AC 97 CODEC AC'97 Codec Device: AD1886 Audio Jacks: M, LI, LO, (Header) SO Speaker CD-In Connector: 1 Internal Spkr-Out/Line-Out/Headphone-Out/Mic-In Header: Yes Onboard LAN Onboard 10/100Mbps Ethernet LAN Supplier: Realtek RTL8100(B) Ethernet Configuration: Down(PCI) Wake-on-LAN, Wake-on-Ring: via PME#(PCI) .....................sodeep
Sep 13, 2009 | E-Machines Computers & Internet
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
Upgrade the shared graphic memory
there should be a setting in the bios to adjust the shared memory with video.
Feb 02, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Graphic Problem
This might be an issue with not having full rights within the BIOS, you could try to enter the BIOS and press F8 this sometimes reveals 'hidden' features.
Dec 20, 2008 | Intel Motherboard
How we can share RAM memory with graphics memory of our PC?
all you have to do is go into the bios, do this by pressing F2 on boot up, when in the bios you need to look for "shared memory" or "graphics memory"
once you have chosen the shared memory you want save settings and exit by pressing F10, the pc will restart and the shared memory will be increased
regards
Nov 26, 2008 | Asrock P4I45GV R5 Motherboard
Graphics problem
Hi, I'm not too sure what motherboard you have, as there are many models that have an intel 845 chipset. But if you can increase your onboard graphic memory, there will be a setting in the BIOS (probably in advanced features) that will allow you to use more RAM towards your Graphics.
If you can tell me the model number of your motherboard, I can see if and how you can increase your total graphic memory.
Aug 30, 2008 | Intel Motherboard
Intel 845 GVSR drivers for windows vista
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Apr 09, 2008 | Intel D845GVSR Motherboard
i don't know weathere you are awared of this or not...
to get the 32 bit graphic on 82845gv motherboard go to BIOS setting and change your video frame buffer size to 8 mb and agp aeperture to 256 mb and let the system boot... you will get 32 bit graphic with 1024 x 748 screen resolution... i have changed and believe me it is working
but only problem is that you will hardly play any game or use bubble screen saver..
Feb 24, 2008 | Intel D845GVSR Motherboard
Intel 845 display driver for windows vista
just click on this link to download display drivers for windows vista:
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/INTEL/Intel-Chipset-software-Installation-Utility-8401009-Alpha.shtml
click on this link to download display drivers for windows-xp
http://www.download.com/Intel-845G-830M-Chipset-Graphics-Driver-Windows-2000-XP-/3000-2108_4-10163599.html
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
Regards :
dilipbagdi
Technical Associate
Nov 17, 2007 | Intel 845GE Motherboard
Intel Motherboard Logo
67 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
