Question about Acer D-Link 2.4GHz Wireless Router 802.11b (DLINKROUTER)
My Acer Aspire 5100 running on Vista will not connect to the internet. This went bad after a support session Norton trying to re-install Norton 360. They ran me through numerous steps, steps I can't remember, and I think something got turned off. I have a stron signal and daughter's laptop connects just fine.
  • 611 Answers
Disable the norton and pc or laptop firewall disable it then try to connect then you connect it then you on your norton and the firewall ok only onces time you have to disable
Posted on Mar 12, 2009
Blank screen, blinking cursor
your problem is your hdd(bad sector).try to regenerate with hdd regenerator 1.71
Apr 21, 2010 | Acer Aspire 5100 Notebook
Installed norton 360 v4 as an upgrade and paid won't staart
Download (as in Save, not Run) the Norton Unistaller
http://service1.symantec.com/Support/tsgeninfo.nsf/docid/2005033108162039
Then go here http://www.symantec.com/norton/support/kb/kbload.jsp?docurl=step_2007102605434976&selected_nav=1&pvid=
and follow the instructions with some additional steps:
Step 2.1 once you have the Uninstaller, the new installer and the key on your pc disconnect it from the internet.
Step 2.2 run the Uninstaller and accept everything it does.
Step 2.3 do yet another reboot and run a sistem cleaner like CCleaner and the Disk Defragmenter
Now do the Step 3 run the installer.
Mar 15, 2010 | Acer Aspire 3000 Notebook
Symantec Client Firewall is blocking my Internet connection
I would recommend disabling the Norton firewall portion of the software, keep it's antivirus side if you wish, and use Windows Firewall for best compatibility.
Jul 15, 2009 | Norton Internet Security 2005...
My camera on computer is not working
actually the vista supported drivers might not be installed ,run malawarebytes to find infection also check for services in services.msc and enable it
May 08, 2009 | Acer Aspire 5100 Notebook
Windows vista installed twice
Um, this may sound silly, but you wouldn't believe how many people simply have the volume turned off in the volume properties. I would then check speaker connections, check that they are still recognized in the device manager, and if all appears well, it may be just a sound card that just up and bit the dust.
Feb 11, 2009 | Acer Aspire 5100 Notebook
No Internet Connection after Installing Norton 360
I had same problem. I went to Start\All Programs\Accessories\System Tools\System Restore. I picked date before which Norton 360 was installed. It got my internet connection back. I'm not even going to try Norton anymore. Time better spent trying to get my money back.
Jan 18, 2009 | Norton Internet Security 2005...
Is norton 360 still incompatible with vista home premium?
Thats not a problem n360 version1,version2.0,version3.0 are compatible with windows vista go ahead and uninstall the nis from add/remove programs and install the n360
Dec 25, 2008 | Symantec Norton 360 for PC (037648318846)
Acer Aspire T180 can't get on internet due to driver corrupt or misssing?
Hello, It sounds to me like there is a conflict between the Kaskersky and Vista. I'd un-install and use Avast but AVG is a Good Anti-virus also. Vista is sometimes a nightmare. I have problems with certain flash-drives which will not work in Vista. They freeze up the computer. It's Vista. Hope this helps. Good luck.
Mar 25, 2008 | Computers & Internet
Drivers for my acer aspire 4720z
acer.com eneter your model in dl vista drivers all to folder on hd ok
Mar 12, 2008 | Acer Aspire 5100 Notebook
Cannot get through internet via ethernet, I Appreciate your help.
You didn't state what kind of net connection you are using, dial-up, cable, sattelite.
If, for instance, you have cable, is the modem connected directly to one computer, or several, via router and ifso on the router is it "wireless" or cable connected?
If you are using anything OTHER THAN dial-up, I recommend, that you unplug the router AND modem, look for "resets" on both, sometimes the reset will look like a small resessed pin that must be pushed on with a pen or toothpick.(hold down for 30 seconds) Leave them unplugged...I would advise 5 minutes, then reconnect cables and power supplys and try again.
If none of this works and you have had electrical storms,(and sometimes wind damages cable if pole mounted) you may have surge-damaged routers/ and or modems. I usually have to reset mine after every lighting storm, and had to replace a damaged router twice. Sadly on another note, I would not recommend vista to anyone, I would however recommend XP media center for computers that have specs for it.
Hope this will help.
Dec 08, 2007 | Acer Aspire 5100 Notebook
Acer D-Link 2.4GHz Wireless Router 802.11b (DLINKROUTER) Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
