Question about Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer filled with water now unresponsive
My wife started the washer with a load of clothes and the washer filled with water. The cycle dial did not move at all, and it will not agitate, spin or drain by moving the dial manually. I've checked the obvious for power at the outlet/breaker not tripped. I read the post on the lid switch, took the two screws out of it and pulled it out past the tub where I could see it and it clicks when I press down slowly on it, but, it also looks like it's either cracked at the gray/black seam, or is in two parts. I'm not sure which. I don't know how to simply open the washer top where I can get to the switch from under the lid... it doesn't just "unsnap" and tip open like in the "olden days", so I'm sure there's a trick or something here I'm missing. Any help would be greatly appreciated.
Bill
  • wburkejr Feb 21, 2009
    First things first! Unplug the washer from the outlet. I tested the outlet and breaker both of which were OK.
    Reading a couple of other posts I figured the lid switch was gone. The lid switch on this model is on the right side away from the hinged lid. The probe/post which engages the lid switch was fine, so I removed the two screws from the back of the washer at the top left and right corners which hold the back of the console to the back of the machine. My machine has two end caps which pop out from the bottom and swing up after which they can be removed and set aside. There are two screws now exposed at the bottom left and right of the console which was covered by the end caps. Remove each of these screws and set aside. You can now gently lift the console up and let it rest over the back of the washing machine being careful not to damage the clear hose connected to the console. There is only one connector going through the washing machine top with three wires. If you have an ohm meter you can stop and test your lid switch here. Disconnect the harness from the machine top connector which goes to the lid switch. The two outside connectors go to the switch, the center connector goes to ground. If you have an ohm meter, attach it to the two outer connectors and depress the lid switch on the right hand side of the top with a screw driver gently until you hear it click. The ohm meter should change and read 0 ohms if the switch is good (mine goes from 0 to reading 0.000. If it's bad, you will see no change. Mine was actually cracked horizontally on one side around the switch body allowing the lever to move the body enough that no contact was being made in the switch itself.
    To get to the switch, remove the two brass colored clips which were under the console using a screwdriver by springing the front of each clip forward. Remove the clips and set aside. The entire outside cabinet of the washer will tilt forward away from the back now by lifting under the back edge of the top of the washing machine body and using the lid which is open, simply tilt the entire body forward to gain access to the switch. There are two screws holding in the switch from the inside of the washing machine edge which must be removed and set aside.
    I ended up fixing the switch rather than replacing it by using a couple of thin zip strips around the outside edges of the switch where the would not interfere with the switch levers action, and then testing with my ohm meter to make sure all was well by manually depressing the switch. I reinstalled the switch, tested it again with the ohm meter after installing it, and all was still good, so reassembled the washer in the reverse order from above, plugged the thing in and problem solved.
    I think the lid got dropped (slammed) on the switch once to often which is what ended up cracking the case of the switch. Appropriate parties have been chastised accordingly to NOT drop the damn lid again. :)
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Kenmore 431423 won't advance cycle, won't agitate
not sure why he would replace the shocks this is clearly a timer/control issue. Replace the main control
Jun 11, 2010 | Kenmore 43142 Front Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washing machine
This is usally a timer problem that is shorted
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Creda machine won't agitate with clothes in it
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Jul 30, 2007 | Creda W120VW Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
545 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
