Question about Compaq Computers & Internet
Where would I look for the usb port
No A: drive, so want to save to sansdisc. Told to plug into USB port. Where is it?
    President:
  • 2,992 Answers
Most Compaqs (in general all brands) have USB ports on both the front and rear of the case. The rear connectors are found where all the other I/O connections are located. They are flat rectangular sockets. When you want to plug in a USB device, you can plug into any open USB port. The plug will also only fit one way, so if it will not go into the connector just flip it over.
Front panel USB connectors are often hidden behind a door. Look for a swing-open or slide-down panel. On some cases the connectors may be on the top or sides.
When connecting devices such as a printer or external hard drive, you should use the rear-panel USB ports. These go directly into the system board and have the best performance. Front-panel USB connectors plug into the main board with cables. For most devices (including your SanDisk) it doesn't matter which you use, but the rear-panel ones are best for high-speed devices or moving lots of data.
You can usually find the user's guide online at the computer manufacturer's website, and that will show you where all the connector are on your system.
If this solution has been what you need, please take a moment to rate it. Thanks for asking here!
Posted on Feb 22, 2009
I own 2 160gb external Pininfarina drives and this one always gives me a pop up window in the task bar saying that the device would work better if plugged into a 2.0 usb port. Every computer I own has a...
Try to reformat the driver using your computer to resolve the problem...after reformatting it...try re-plug it again to the usb port. If the notification still exist...that will be version incompatibility...you need to update the usb port driver...
Go to the website of the motherboard name and download the new updated version of the usb driver...If your motherboard is msi...go to msi website...something like that
Sep 21, 2011 | SimpleTech Signature Mini 160GB External...
I just started a new update on xbox but i get the message that it cant read the update from my storage device and that i have to reinsert it.. help me!
UPDATE VIA USB DRIVE Note The USB flash drive must use the FAT32 file system.
  1. Plug your USB flash drive into a USB port on your computer.
  2. Download the update file.
  3. Click Save to save the console update .zip file on your computer.
  4. Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  5. Copy the contents of the .zip file to the root directory of your flash drive.
  6. Unplug the USB flash drive from your computer.
  7. Plug the flash drive into a USB port on your Xbox 360 console.
  8. Restart the console.
  9. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
I would try this if it is having a issue connecting to the update.
If you are satisfied with this reply please thumbs up or write a testimonial good luck!
Jun 01, 2011 | Video Game Consoles & Games
My computer suddenly started signaling that a power surge problem, a usb hub has exceeded the power limits. i was told to uninstal the usb ports and install again. i did and starts to work when i plug in a...
If you are using a usb hub it could be the problem; try disconnecting the hub. Try to plug the pen drive into a usb port on the pc not on a hub. If the usb hub has a separate power supply make sure it is working. Hope I was of some help, Thanks for using FixYa
May 11, 2011 | Computers & Internet
Code popped up 3151-0000-3080-0506-8007-2EE2 what does this mean...trying to down load game
This is a rare X-Box related error that pops up when there was a system issue with an update. The easiest way to resolve this matter is with a flash USB drive; I'm hoping you have one.
  2. Download the update file from http://www.xbox.com/system-update-cd
Best of luck...
Mar 06, 2011 | Computers & Internet
When I plug the USB cable into printer, computer does not see the printer. I have tried two different cables and ports. HP Tech support told me that there is something wrong with the USB connection port on...
refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB drive
Nov 11, 2010 | HP Photosmart D5069 InkJet Printer
Dont know how to use it
plug it into a USB port then click start all programs accessories scoll to windows explorer open my computer you should see this drive you can save music,data,files ,programs when downloading just select this drive to save in
in xp
Oct 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Sir/ma'am i have got a new laptop , but i don't have many drives....i mean i have only C- drive and i have to save everything in my desktop..... hope you solve my problem....... ty poojitha
getting a memory stick you plug into one of the USB ports might be an option--Make sure you buy one that is compatable with your filesystem/operating system.
There are two main commercial types of Usb port 1.1 and 2.0
most memory sticks these days cover both types
your pc'should recognise the Usb stick as a different drive E or F for example from there save and wait for save process to stick
Sep 06, 2010 | Computers & Internet
How to imput image on screen
Plug it into the UBS port, or save the picture in a USB Drive than Plug into the USB port of the TV.
Apr 17, 2010 | Samsung LN40A530 40 in. LCD TV
I have plugged in my Crusr SabDisk 4 GB to my usb,
Check the drive by plugging it in to another computer (with known working ports) or another port that you have tested with another device. Some machines have USB ports disabled for power-savings and security so you can check that in the device manager. Ports can also fail with time.
If the drive doesn't work in another computer or a known good USB port, it's probably failed. Check your warranty and you might get a new flash drive. However, you won't be able to get the data off of it without spending money for data recovery.
I hope this helps.
Feb 16, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do I re format my pen drive "cruzer micro 4 gb" for my MAC (Sansdisc)
connect to usb and your pendrive will be displayed ..........just right click and click format option ........ your pen drive will be formatted ............
Oct 21, 2008 | Computers & Internet
Computers & Internet Logo
114 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
