Question about Gateway 4530GZ Notebook
Black lcd display no backlight just very dim
Comment posted on Feb 21, 2009 hi and thanks for the assistance. I have taken just about the whole laptop apart looking for the inverter and I cannot see anyplace where it might be or where it should be. On one of the help tutorials the person worked on a Gateway 450ROG. This was the only thing close to the Gateway 4530GZ so I followed the instructions thinking both Gateway laptops would be somewhat close in design. So I took out the keyboard bezel, and the keyboard because the invertor should have been right there under the top front of the keyboard but it wasn't. I did find a couple more tutorials one for Dell and in fact I believe the other may have been yours on the Sony, good piece by the way.
I did take apart the display but I don't see any place where the inverter should be there either. on the bottom side of the LCD, (the side that fits closet to the keyboard, ) is where this little connector and wire comes out. It was out about 2". it is a thin black wire and a thin white wire with a small plastic connector at the end, the connector almost looks like an electrical appliance plug. there is no obvious place where this came unplugged from.
the other wiring that comes from the screen has the red, green, yellow,black and white wires and this is plugged in at the left upper most side right under the hinge. the other connector could not possibly reach this far if there was even a place to connect it.
this comes out from the right side (when facing the screen) to the bottom middle of the screen. there is nothing under or inside the lcd screen or the keyboard area or even on the bottom of the laptop. I have that apart too. I'm sure I'll have a blast getting all this back together. : )
at any rate, I think that my son and/or one of his friends probably unplugged this thing from somewhere when they "took a look at it". neither of them can remember where it was plugged in at though. nor can the friend that I took it too. everyone has looked and looked and we find nothing, Gateway is no help as of yet. I emailed the tech support and haven't received any info yet. I haven't found any support documents for this either except the description that this is the gateway intel chipset whatever.
does any of this make sense? I'm not going to give up on this thing until I find that daXXX inverter. I even looked one up on Ebay just to see what it looked like thinking it would help me pinpoint a little easier where it was located on the laptop but.....
  • tgsmith2090 Feb 21, 2009
    thank you womonsoft7. the multi-wire assembly is plugged in and I'll look for where the other should fit as you described.
    does this black and white assembly plug in the screwhole or is just held in place by the screw?
    I appreciate you're taking the time to help me
    have a good one today/ thanks
    President:
  • 2,653 Answers
It's underneath the front of the lcd bezel. Pretty much every laptop is the same. You don't need any special guides.
http://images.channeladvisor.com/Sell/SSProfiles/13000207/images/16/INV-GY-004.jpg
That's what it looks like in case you're wondering.
Posted on Feb 21, 2009
  • 66 Answers
The inverter should usually sit on the right side of the display. The thin black and white wires with the "appliance plug" on the end is held at the bottom of the display by one of the smaller screws. It fits onto the screw hole and is held by the screw at the bottom right/middle. The red/green/yellow/black/white set of wires is hooked into the display near the hinge and the other end is plugged into the board on the base unit of the laptop itself. Hooking the monitor back up is kind of a pain given the amount of parts/screws but it's more time-consuming than difficult. Good luck and I hope I helped some :-)
Dim display problem
Have you tried adjusting the LCD's bright and contrast using the buttons on the monitor. Instructions can be found on page 12 of this manual:
https://computinghardware.web.cern.ch/ComputingHardware/doc/Samsung/SyncMaster740B/SyncMaster740B-940T-E.pdf
If the lcd monitor is dim even upon booting up, then the backlights of the lcd itself is starting to fail and it needs to be replaced.
Please let me know if you need further assistance. Thank you for using FixYa. Merry Christmas!
Dec 25, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Have beko 32inch L C D , when i power on it comes on for a 5second and then the screen goes black, i still have sound, just no picture? model no 32WLK53OHID ITS NOT LED TIS IS LCD
Hi
Thanks for using FixYa. To check what has gone bad you’ll have to open the back of the unit and check the backlight inverter board. The inverter is the power supply source for the backlights. If that’s the issue then it’s always better to replace the inverter board completely just to avoid any future issues. If not then check the power supply board however, it seems to be the inverter board as the sound is still working fine.Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 01, 2010 | Televison & Video
HP compaq 6710b - Hi I can't adjust the brigthness of my screen from my keyboard anymore. I used to be able to hold down the "fn" key and then press "f9" to decrease or "f10"to increase the brightness. Now...
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 30, 2009 | HP Compaq 6710b Notebook Pc
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
D600 Latitude laptop - LCD showing ghost/dim images
Connect an external monitor to your laptop and power it up, if you seethe normal Windows images then the video card and laptop is OK and theproblem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dimimage and/or dark display on the laptop's LCD screen indicates a faultyLCD backlight and it could be the inverter that supplies high voltageto the CCFL lamp or it is the CCLF lamp is nearly burnt out or burntout, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
Thank you Sir, Have a nice day.
Sep 19, 2009 | Dell Latitude D600 Notebook
Evo N600C, display is 'dim' and mainly 'red'
There is one CCFL lamp on the bottom edge of the LCD screen.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 04, 2009 | HP Compaq Evo Notebook N600c
Elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
Jul 08, 2009 | Computers & Internet
My Dell Inspiron 1300 wont start
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
May 09, 2009 | Dell Inspiron 1300 Notebook
Screen keeps going black, and sometimes computer restarts
  • Picture flickering with dim display.
May 03, 2009 | IBM ThinkPad T42 Notebook
Lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
Mar 31, 2009 | Dell Precision M60 Notebook
Gateway 4530GZ Notebook Logo
446 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
