Question about Asko 1375 Dishwasher
Need the wash impeller for a asko 1585 - Asko 1375 Dishwasher
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
TheySell complete pumps not separate impellars. sorry.
Posted on Aug 06, 2009
Asko 1875 had a new main board, wax motor and temp thermistor fitted 6 months ago. now thw machine pumps in the water but does not wash what could be the problem
Hello, welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko 1875 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, unfortunately.
First though, do you hear a quiet sound of the wash motor starting once the unit has completed filling with water ? And be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues.
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely.
This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet...you may opt to call in a pro.
I'll watch for your reply and try to help in any manner I can.
Regards,
Macmarkus :)
May 20, 2011 | Asko D1876 Dishwasher
The spray arms on my Asko 1716 dishwasher do not turn - water enters the unit and drains easily, and the heating element also seems to work. The filters and sump are clear, as are the air gap and the holes...
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1716 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, as you mentioned. What you may not know, is the impeller itself is not serviceable, the entire motor/pump must be replaced unfortunately.
Before declaring it is indeed a motor/impeller issue, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? And be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump obviously it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues.
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump or severed somewhere between the motor and control, maybe where the door pivots during opening...but not likely.
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet. Check those other possibilities first and tell me what you find.
I'll watch for your reply.
Regards,
Macmarkus :)
Mar 09, 2011 | Asko 1375 Dishwasher
After filling with water it fails to wash.Washers inside the unit are not spinning around.
Hello, Welcome to FixYa. Based on your description and provided the dishwasher is indeed 1) an Asko D1706 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, unfortunately. First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? ( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues ) If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design. What happens typically is the ball-bearings from the upper rack holders ( the holders which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor. Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet...you may opt to call in a pro. I'll watch for your reply. Good luck. Regards, Macmarkus :)
Dec 10, 2010 | Asko D1706 Built-in Dishwasher
On my model 1475, the washer arm doesn't seem to be working and the wash cycle isn't working. It still fills, drains, and goes to the heat cycle. . .but we don't think it is doing the actual washing. ...
Hello, Welcome to FixYa. Based on your description and provided the dishwasher is indeed 1) an Asko 1475 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, unfortunately. First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? ( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues ) If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design. What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor. Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet...you may opt to call in a pro. I'll watch for your reply. Regards, Macmarkus :)
Nov 26, 2010 | Asko 1375 Dishwasher
It seems like there is not enough pressure to activate the cleaners they barley move,i have watched it while it was open its trying to work
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed filling with water but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump.
( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver )
This unfortunately is common with Asko dishwasher and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders fall out making their way into the sump, hence breaking the wash impeller from the motor.
Good luck,
Macmarkus :)
Aug 24, 2010 | Asko D1776 Built-in Dishwasher
Asko1585 sprayer arm not working
Most likely the circulation pump. On this pump there is mounted a condensator. This will help the pump to get started. If this is broken, it wont circulate the water up to the sprayers.
Jul 15, 2009 | Asko D1776 Stainless Steel Built-in...
Asko 1585 wash cycle goes continuously until manually shut off
it may be a heating problem,does it get hot at all, or over heat.may be a thermistor fault.remove the door skin and see if rinse aid has leaked onto the wiring.or the board itself cauld be faulty,but are very expensive.hope this helps.
Mar 22, 2008 | Asko 24 in. 1585 Built-in Dishwasher
Asko 1375
May be the drainpump that has something stuck into it. Check that:)
Nov 23, 2007 | Asko 1375 Dishwasher
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Asko 1375 Dishwasher Logo
231 people viewed this question
Top Asko Dishwashers Experts
Mike Cairns
Mike Cairns
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
