Question about Maytag Dryers
Maytag LDE8414RCM, dryer knocks and rumbles while running. Still heats and dries clothes for the moment, but the knocking and rumbling is getting worse. Thanks
  • jstone17 Feb 21, 2009
    Here's some added info. I turned the drum manually while listening closely. The rumbling noise is still there and seems to be coming from below the drum. The rumbling continues while I turn and even continues for a second after I stop the drum from turning.
    President:
  • 2,992 Answers
That rumbling noise may be due to the fan impeller being loose on its shaft, or because of a worn rear support roller. If the machine is still drying, it may be taking longer than usual but you haven't noticed. This is a good sign it's the fan. There are a number of sites with good detailed procedures for getting at and replacing parts, as well as selling the parts you need (of course they would!). One of them is here:
http://www.applianceaid.com/maytag-dryers.html
If this solution gets you on the way to quiet drying, please take a moment to rate it. Thanks for asking here!
Posted on Feb 21, 2009
  • Feb 21, 2009
    That would tell me definitely fan blade, then. The fan is driven by the same motor that's turning the belt. So when you turn the drum, it also moves the fan, and because it's loose on the shaft the fan continues to move a while after you stop turning. The fan is under the cover you see below the drum, in front of the motor.
Maytag Neptune front loading electric dryer rumbles. I changed the belt and rollers, but the problem persists. What can it be?
Check the blower wheel, A lot of time the blower wheel gets bored out where it connects to the motor shaft and basically just knocks around. A good test is to start the dryer, wait for the rumbling to begin then open the door. If the blower wheel indeed is the problem, the sound will continue for a brief moment after the door opens. I posted a link below to help, hope its close since I didn't have a model number. #15 is what your looking for in your machine.
http://www.partselect.com/ModelFrames.aspx?ModelID=128410&ModelNum=MDG6700AWW&mfgModelNum=&ManufactureID=1&Selected=58665&Position=4&mfg=Maytag&Type=&Mark=4
Jun 22, 2012 | Dryers
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Aug 19, 2011 | Maytag LSE7806A Top Load Stacked...
Drum rumbles when dry cycle started
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 10, 2011 | Dryers
The dryer is making a squeeking noise as it turns then turns into a big rumble like it might be off track. And it's loud! Belt is tight. Help!
heatman101
Asker
Jan 10, 2011 | Maytag Dryers
Dryer is making a loud rumbling noise when drying - it is drying okay - but making a rambling noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 04, 2011 | Asko T761 Electric Dryer
Dryer initial had rumbling sound when started and then quieted down to normal. It now makes a rumbling sound through the complete dry time
heatman101
Aug 31, 2010 | Maytag MDE2600 Electric Dryer
My dryer rumbles when it is spinning. But it also
The drum support rollers are worn. This will cause loose belt tension and a rumbling sound. You will need to pull the drum to find the rollers at the lower back of the drum. Check the roller shafts for wear and replace them at the same time as the rollers if needed. Check the belt and tensioner for wear before reassembly. This should fix ya...
May 08, 2010 | Dryers
MayTag Neptune MDE6800AYW dryer drum making rumbling knocking noise
Have someone change the bearing, it sounds like it has busted on ya. The rumbling sounds like the ball bearings in the bearing have failed.
Jul 09, 2009 | Maytag Neptune MDE6800 Electric Dryer
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
My Maytag dryer is rumbling when it starts up. But, it is drying OK.
Check for loose 'tumblers' inside the drum. I have heard of some cases of these coming loose and causing knocking in the drum.
Jul 01, 2008 | Maytag Dryers
Dryers Logo
292 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
