Question about Westinghouse 25.5" Widescreen Flat Panel LCD HD Monitor
Out of range box shows up on monitor
Computer is Macbook Pro.   The manual says "set screen resolution to panel native resolution at 60 hz"    I don't know what that means.
Have to set computer to 11440x900 resolution and make sure it stays there.
Posted on Aug 31, 2009
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Sep 10, 2014 | Envision Peripherals 22"" envision e218c1...
DISPLAYING ON SCREEN THAT VIDEO INPUT OUT OF RANGE
Right click on the back ground of the computer desktop. If windows XP click properties, if vista click personalise. Now look for settings and move the resolution slider to 1024 X 768. This is the native resolution for this monitor.
If you still have the HZ error, click on advance look for the monitor tab, and make sure it is set to 60Hz
Mar 02, 2012 | NEC MultiSync LCD1525V (White) 15.1" LCD...
When monitor blinks a analog box pops up and the box says somthing like 1920x1200 60 hz. what does this mean?
It is telling you that it wants you to set your PC video resolution to the monitor native resolution of 1920x1200 @60 hz.
You may be able to turn off the resolution notification in the on screen setup menu.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Aug 12, 2011 | ViewSonic VX924 19" LCD Monitor
Input not supported
The repair shop set the PC video resolution to higher resolution to use with their monitor and did not put it back to the same resolution for your monitor which cannot handle the higher resolution. You need to lower the PC video resolution to the native reslution of your monitor which is 1280 x 1024 @60 Hz.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://s807.photobucket.com/home/budm/allalbums
Jul 14, 2010 | Envision EN-7100e 17" Flat Panel LCD...
Hello I can't get anything on my screen except
Your PC is putting too high resolution for he VL1918 to display.
You need to set your PC video out put to the native resolution of the VL1918, which is 1280x1024 @60Hz.
You will have to hook up your old monitor (crt type?) and set the new resolution.
Or boot up in safe mode (hit f8 during boot up), and set the resolution to 640 x 480, reboot into regular mode, then rest the resolution to 1280x1024 260Hz.
Also watch out for bad caps in this monitor: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Apr 07, 2010 | Princeton Digital VL1918 Monitor
Input signal out of range and the monitor keep going off
Your PC is putting too high of the resolution for the monitor to support. You need to set your PC video resolution to 1280 x 1024 @60Hz (native resolution) for this monitor. Bootup in safe mode (hitting F8 key during bootup) and set the resolution to 640x480 then reboot in normal mode, then reset the resolution to 1280 x 1024 @60 Hz.
Feb 23, 2010 | HP vs17c 17" LCD Monitor
Frequency out of range 11khz/ 119khz message
The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
Jan 12, 2010 | Envision H191W Monitor
Out of Range
Boot in safe more. Tap the F8 key while the computer if booting. Keep tapping it. A boot menu will come up. Chose boot in safe mode.
in windows, right click on the desktop and select properties. Go to the rightmost tab, and use the slider to set the resolution to 800 x 600.
Reboot your computer. Let it boot normally. Go back to the resolution slider and set it to either 1280 x 1024 (4:3), or 1440 x 900 (widescreen) depending on what type pf monitor it is.
Mar 17, 2008 | Westinghouse L1975NW Monitor
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
Westinghouse 25.5" Widescreen Flat Panel LCD HD Monitor Logo
149 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Paul Bade
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
