Question about GE GSH25JFT
Water dispenser in door stopped working
I have a GE GSH25JFTA BB refrigerator and the water in the door stopped working. The ice is working fine. The water is getting to the bottom of the freezer door.
  • 1 more comment
  • Anonymous Mar 13, 2009
    water just stopped dispensing one day. put in a new water filter and still not working
  • Festus Smith May 06, 2009
    I have same issue. Water in the door freezes and stops working. Have to open the freezer door and allow it to warm to get it to start dispensing water again.
  • Jonathan Moore
    Jonathan Moore May 17, 2009
    I appear to have [had] the same problem.  Open the freezer door and let the water line thaw.  I put a sheet of plastic and a sheet of foam insulation over the freezer opening while the door was open to keep the cold in.  The water dispenser will not work with the freezer door open... so you just need to reach in at the top and hold the door switch down to check to see if the line has thawed.
2 Suggested Answers
SOURCE: GE refrigerator freezer water dispenser failure GSH25JFTA
Some have said that if you are fridge is still making ice, then your water line may be frozen. So you need to let it thaw out by leaving the freezer door open. Figure out somewhat to try and keep the cold air in by using plastic sheeting or something, until the line thaws. You can't dispense water with the door open, so reach up press the button that makes it think its closed and try to dispense the water..or just shut the door to test it out. I am going to try this when I get home today, because I am having the same problem on my GE model# GSH25JFTA BB.
Posted on Mar 29, 2010
  • 1891 Answers
SOURCE: GE GSH25JFTA refrigerator has stopped dispensing water. Ice is OK
change the tempt of freezer if too cold it will freeze line . try seting it for 5 to 20 deg some run below 0 and will freeze the water .. mm
Posted on Jul 29, 2010
Water in side by side door stopped working ?
got a problem alright
water may have got to the electrics
needs a GE authorized repairer to check
safety first
turn wall power switch off and unplug from wall
if desperate buy some bagged ice to preserve fridge contents
Oct 14, 2016 | GE Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
GE GSH25JFTA BB water dispenser not working but ice cube maker working fine
Ice maker is working. Water dispenser is not working. I did the initial diagnosis and the water line is not frozen. How do I replace the water valve or is that the right next step?
Jan 05, 2012 | GE GSH25JSTSS Stainless Steel Side by Side...
Jul 29, 2010 | GE Refrigerators
Water dispenser doesn't work, side by side, model # GSS22JEPA BB
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Mar 04, 2010 | GE Refrigerators
Mar 02, 2010 | GE GSH25JFT
Not getting any water out of my dispenser. The light indicator is on but when I push in the dispenser lever no water comes out??? My ice despensor is working fine, Indicator lights are working fine. I...
I have the same problem with the same refrigerator, call up GE Customer Service and tell them that you want part number WR49X10173, a water dispenser heater kit. They should sell it to you for a "discounted" price of $25. Good Luck, and don't ever by GE anything ever again.
Jan 15, 2010 | GE GSH25JFT
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
WATER IN DOOR
bad solenoid assembly maybe
Jul 05, 2007 | GE GSS25SGMBS Side by Side Refrigerator
GE GSH25JFT Logo
228 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Da Doc
