Question about Microsoft Xbox 360 Console
Power pack is orange and system won't turn on?
  • 27 Answers
Try to unplug the power from the back of the console and let it sit for 5 minutes. somtimes i had this happen and press the button a lil harder and it woked. also try to remove the faceplate and use a little screwdriver or something to press the button in there. you're faceplates button might be broken(replace faceplate)
Posted on Feb 21, 2009
ML600 won't turn off
The clock module for power pack is not sold separately.
Set timer to auto using override knob so lights are on, then plug power pack into cheap timer.
Check outlet with circuit analyzer.
Try connecting power pack to another outlet.
Copy following link for warranty information, tips to help power pack last longer, links to trippers, troubleshoot, etc.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jul 15, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
My vizio e371vl will not power on but the orange vizio stays on
The main board is usually at fault in a vizio when the logo doesnt turn white which indicates the main board isnt processing the power on command. You can get free technical assistance to troubleshoot that model by contacting the guys at www.tvrepairworld.com
Mar 21, 2012 | Vizio Televison & Video
98 cherokee turns over but won't start no power to wiring at fuel pump an on the dash ther is a orange key with a line throw it what does it mean
This indicator light is related to the vehicle security system, which checks that the key you are using is authentic. If it is flashing, you have a key with no chip in it, a bad ring antenna, or other fault in the security system.
Instructions
    • 1Turn the ignition switch off.
    • 2Insert the key into the driver's side door.
    • 3Turn the key clockwise to lock it.
    • 4Turn the key counterclockwise to unlock it. The alarm system recognizes an authorized key was used and the system resets.
      As a side note if that doesnt work try it in the rear hatch. good luck hope this helped.
Dec 01, 2011 | 1998 Jeep Cherokee
Poweredge SC 1420 won't come on, it keeps blinking an orange light on the power button and the lights below the power button the first 3 indicator lights are orange. I tried unplugging and plugging it...
hi,
I have several of these and most often there power supplies blow. since they come by default with only one powser supply. the system won't start
I would start there as most other problems will generate beeps.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 17, 2011 | Dell PowerEdge SC1420 (SC1420MIN) Server
Won't work timer out
If light still turn on with override, then plug power pack into cheap in-wall timer.
Open following link for ML series troubleshoot steps and information:
Jun 25, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
When we power the computer on the power light stays orange and does't actually start up. How do we fix this?
hello.
to fix this,
get screwdrivers and open up the computer,
check the cables that are connected from the power pack to the motherboard,
check all cables that are in the system if they are properly attached,
remove and reconnect them,
couple back the system and try turning it on again.
Jun 12, 2010 | Dell Dimension 4600 PC Desktop
I have no power cant turn xbox on theres a orange light on power pack?
This means that there is a problem with your power supply, because it cannot put out enough power to be used by you Xbox 360. My suggestion it to buy a new power supply to replace the one you have now before anything might happen to your system.
May 07, 2010 | Microsoft Xbox 360 Console
No power in console, but light is on ,on the power pack
This is normal. The light will always be on if the power pack is plugged into the wall. There should be no lights lit on the Xbox if the power is turned off, but the power pack will still have an orange light.
May 02, 2010 | Microsoft Xbox 360 Console
Forgot bios password
1. Shut down the computer. If you are unsure whether the
computer is off or in Hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery pack by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch 1 to the left. (The
front edge of the battery pack disengages from the
computer.)
c. Lift the front edge of the battery pack 2 and swing it
back.
d. Remove the battery pack.
5. Remove the RTC battery from the socket on the system
board.
6. Wait approximately 5 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any
battery packs at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
May 07, 2008 | HP Compaq Presario V2000 Notebook
Microsoft Xbox 360 Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
