Question about Miele Dryers
Miele T1526 Dryer loud brushing sound
Has anyone had a problem with a loud not banging but brushing sound when the dryer barrel is running? I think it has something to do with the baffles.
  • David Shaub May 11, 2010
    You could have something stuck in the brush around the drum opening. A button or a penny could have gotten lodged in there.
catriver
  • 878 Answers
SOURCE: dryer makes banging noise
basscat, you first remove the door by removing the screws from the hinges. The door will lift up a litte and pull off. Next remove the spacers on the other side. Now the front panel will pull out from the top. There will be two 1/4 inch screws with latches on each side of the frame, remove these and the top will lift up. Now by holding the door switch and starting the dryer, you will be able to see what is banging. Once you determine that, you can remove the bulk-head, should be 4 screws, be sure to unplug the door switch. Unfasten the belt, remember the configuration and remove the drum. You are now able to get at the insides. Catriver..post back.
Posted on Oct 02, 2006
MNTECH
  • 1543 Answers
SOURCE: dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
Posted on Nov 18, 2008
SOURCE: Dryer has a banging noise
It Is fixable.All you need to is try to balance the load or a perfect concrete flat surface for the machine.
If the problem still persists, then during the previous vibrations, the shocks or the drum bearings might have been damaged, you might have well replace them to avoid further problems.good luck.and please post your comments.
Posted on Apr 11, 2009
  • 70 Answers
SOURCE: No heat out Miele T234C dryer.
Most likely fault is filters have been clogged and tripped the safety stat on rear of appliance. Wash filters and replace stat Part No. 5432530
Posted on Mar 28, 2010
heatman101
  • 43501 Answers
SOURCE: My dryer is making a loud banging noise on the
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
76fg
Posted on Sep 29, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
How to put top back on miele w1926
1 Remove stacking kit from top of unit.
2 Reatach the two plastic clips to the back of washer.
3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
Dec 29, 2013 | Miele W1926A Front Load Washer
My drum doesn't turn anymore after I have used the basket. It now does a loud humming sound.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Miele T9800 Electric Dryer
The barrel won't spin. the heat is still working, but the barrel won't spin. i may have overloaded the dryer (five pairs of jeans and three hooded sweatshirts) there was a loud bang noise and the barrel...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Dec 29, 2010 | Dryers
My kelvinator dryer began to squeak loudly and now it will not run. When I push the start button, there is a sound, but the dryer would not work.
sounds like the barrel has jammed try turning it by hand to see if its jammed if so then it will need to be serviced by a lic tech if the barrel is free turning then i would say it has broken its belt the sqeaky noise would be its bearings wearing out putting the barrel out of alyghnment this too will need replacing
merry christmas
Dec 22, 2010 | Dryers
Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
Feb 18, 2010 | Miele T9800 Electric Dryer
Miele T358C Dryer Blew up!
it could be a shorted heating element a shorted to the case, motor start capacitor, or a defective motor ,f i would inspect the first two items closely
Sep 20, 2009 | Miele Novotronic T240 Electric Dryer
Maytag dryer making a loud banging sound
are there shoes in the dryer?is the dryer level?
Aug 16, 2009 | Maytag PYE2300AY Electric Dryer
Bang, Bang, Bang. That is the sound my dryer
try taking yoga classes and put your dirty yoga clothing in the dryer and that should calm her (meaning your dryer) down.
May 06, 2009 | Dryers
Dryer making loud squeaking sound
Try checking the glide wheels under the barrel they may need to be cleaned and lubed.
Mar 11, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
87 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
