Question about Kenmore 24032\24036 Top Load Washer
80 series kenmore filled with water and then won't agitate, spin or drain.
  • wburkejr Feb 21, 2009
    See my other solution to this problem. Bad lid switch with detailed description of diagnosis and repair (not replacement of switch).
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!
Posted on Sep 14, 2010
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
Kenmore 80 series washer fills but does not wash/agitate. will spin and drain when manually turning dial to spin
The agitator dogs may be broken or the transmission could be bad. Try checking the agitator dogs first. They are an easy and inexpensive fix.
Aug 31, 2009 | Kenmore Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
305 people viewed this question
Sal De
fordexpert
Robert Rankin
